i am getting a System.InvalidProgramException
I’m actually getting an error
System.InvalidProgramException occurred
  HResult=   0x8013153A Common Language Runtime detected an invalid program.
  Source=<Cannot evaluate the exception source>
  StackTrace: at Autodesk.AutoCAD.DatabaseServices.Database.get_TransactionManager()
While running this below piece of code
                    Database sourceDb = new Database(false, true); //Temporary database to hold data for block we want to import
                    try
                        sourceDb.ReadDwgFile(dwgPath, System.IO.FileShare.Read, true, ""); //Read the DWG into a side database
                        ObjectIdCollection blockIds = new ObjectIdCollection(); // Create a variable to store the list of block identifiers
                        Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = sourceDb.TransactionManager; using (Transaction myT = tm.StartTransaction())
                            // Open the block table
                            BlockTable bt = (BlockTable)tm.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, false);
                            // Check each block in the block table
                            foreach (ObjectId btrId in bt)
                                BlockTableRecord btr = (BlockTableRecord)tm.GetObject(btrId, OpenMode.ForRead, false);
                                // Only add named & non-layout blocks to the copy list
                                if (!btr.IsAnonymous && !btr.IsLayout)
                                    blockIds.Add(btrId);
                                btr.Dispose();
                        // Copy blocks from source to destination database
                        //IdMapping mapping = new IdMapping(); sourceDb.WblockCloneObjects(blockIds, _database.BlockTableId, mapping, DuplicateRecordCloning.Replace, false); _editor.WriteMessage("\nCopied " + blockIds.Count.ToString() + " block definitions from " + blockToImport + " to the current drawing.");
_gile
From your other posts, it seems you're trying to directly use the AutoCAD .NET API from a standalone executable.
Read this topic about out-of-process vs in-process applications.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
vsraman85
Hi, any solution for this? How to resolve this issue? I am also having the same issue
