How to respond to an add-in's window (pop-up) in AutoCAD programmatically ?
Kh.mbkh
Kh.mbkh
When starting an AutoCAD add-in (with the command "StartPlong"), a pop-up window appears:
I wonder if it's possible to answer this window (pop-up) by checking the CheckBox1, clicking the button 2, and 3 ... programmatically.
By searching on the Net, I found some solutions (Use Spy++ to get hundle of buttons ... ) but can't come up with a solution.
N.B.: We don't have any information on the language used to create this foreign Add-in
Thanks !
_gile
What you are trying to do is hacking. You will not get any help on this forum to do that.
You need to go directly to the publisher of this add-in.
Gilles Chanteau
GileCAD
GitHub
Kh.mbkh
It seems that you didn't understand what "Hacking" is...
So for anyone who may be interested, I fixed my issue using PywinAuto (A Python library) to do Scraping.
jhsct
Observer
Observer
I use AutoIt for things like this.  The nice thing is that it has a .NET API so I can incorporate the code directly into my plugins.
FYI, I do not believe that this is considered hacking but would rather fall under automation as all that AutoIt is doing is moving the mouse for you and/or clicking buttons, or....
