Here's an example using a Jig (instead of PointMonitorEventHandler and TransientManager).
The jigged perpendicular line is red or green according to the side of the source line the cursor is. The reference vector is the current view direction.
[CommandMethod("TEST")]
public void Test()
var doc = Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
var options = new PromptEntityOptions("\nSelect line: ");
options.SetRejectMessage("\nSelected entity is not a line.");
options.AddAllowedClass(typeof(Line), true);
var result = ed.GetEntity(options);
if (result.Status != PromptStatus.OK)
return;
using (var tr = db.TransactionManager.StartTransaction())
var axis = (Line)tr.GetObject(result.ObjectId, OpenMode.ForRead);
using (var perp = new Line(Point3d.Origin, axis.GetClosestPointTo(Point3d.Origin, true)))
var jig = new PerpendicularJig(perp, axis, ed);
var pr = ed.Drag(jig);
if (pr.Status == PromptStatus.OK)
var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
curSpace.AppendEntity(perp);
tr.AddNewlyCreatedDBObject(perp, true);
tr.Commit();
class PerpendicularJig : EntityJig
Point3d dragPoint;
Line axis, perp;
Vector3d axisDir;
Editor ed;
public PerpendicularJig(Line perp, Line axis, Editor ed) : base(perp)
this.axis = axis;
this.perp = perp;
axisDir = axis.StartPoint.GetVectorTo(axis.EndPoint);
this.ed = ed;
protected override SamplerStatus Sampler(JigPrompts prompts)
var options = new JigPromptPointOptions("\nSpecify a point: ");
options.UserInputControls = UserInputControls.Accept3dCoordinates;
var result = prompts.AcquirePoint(options);
if (result.Value.IsEqualTo(dragPoint))
return SamplerStatus.NoChange;
dragPoint = result.Value;
return SamplerStatus.OK;
protected override bool Update()
using (var view = ed.GetCurrentView())
var viewDir = view.ViewDirection;
perp.StartPoint = dragPoint;
perp.EndPoint = axis.GetClosestPointTo(dragPoint, viewDir, true);
var xform = Matrix3d.WorldToPlane(viewDir);
var v1 = axisDir.ProjectTo(viewDir, viewDir);
var v2 = perp.EndPoint.GetVectorTo(dragPoint).ProjectTo(viewDir, viewDir);
perp.ColorIndex = v1.GetAngleTo(v2, viewDir) < Math.PI ? 1 : 3;
return true;
