.NET
How to pick edges in Solid3D
6 REPLIES 6
strsuraj
677 Views, 6 Replies
I have a solid3d and would like to fillet the edges, picked by me.
I came across below code, but it filters all the edges of selected Solid3d sol and does fillet.
ObjectId[] ids = new ObjectId[] { sol.ObjectId };
SubentityId subentId = new SubentityId(SubentityType.Null, IntPtr.Zero);
FullSubentityPath path = new FullSubentityPath(ids, subentId);
List<SubentityId> subentIds = new List<SubentityId>();
DoubleCollection radii = new DoubleCollection();
DoubleCollection startSetback = new DoubleCollection();
DoubleCollection endSetback = new DoubleCollection();
using (Autodesk.AutoCAD.BoundaryRepresentation.Brep brep = new Autodesk.AutoCAD.BoundaryRepresentation.Brep(path))
    foreach (Autodesk.AutoCAD.BoundaryRepresentation.Edge edge in brep.Edges)
         subentIds.Add(edge.SubentityPath.SubentId);
         radii.Add(6.0); startSetback.Add(5.0); endSetback.Add(0.0);
sol.FilletEdges(subentIds.ToArray(), radii, startSetback, endSetback);
How can I pick edges after selecting the solid ??
Thanks in advance.
Tags (3)
6 REPLIES 6
SEANT61
in reply to: strsuraj
This thread does not answer your question specifically, but it may offer some information to assist the quest:
https://forums.autodesk.com/t5/net/select-lines-and-faces/m-p/7754428#M57408
May your cursor always snap to the location intended.
strsuraj
in reply to: SEANT61
Hi Seant, thanks for your reply. I went through that link and got quite a logic about how to proceed further.
Now I am able to pick as many edges I wish to and fillet does happens but only at the first edge picked by me. Even the PromptSelectionResult shows Count as 1. Can you help with this.
I have made ForceSubSelections = true; so has it got anything to do with giving back just one edge as selection.
SEANT61
Hi @strsuraj,
Most of the Face Area routine was written quite a while ago.  I’m pretty sure that the same general process would work with edges as well, but I need to review my code to re-acquaint myself.
In the meantime, why don’t you post your current code.  We should be able to get something working.
Sean
SEANT61
The code in the Swamp.org link can be modified to isolate edge selection.  In the attached screencast, I just used a hardcoded radius amount, though that too could be part of the user interaction.
Give the modification a go.  There are a couple of areas that may throw a roadblock; let me know if you need some assistance.
strsuraj
hey Seant, thanks. That code in Swamp link really helped.
SEANT61
You're welcome.  I'm happy that it helped.
Technology Administrators
