.NET
How to force Command Line Focus
4 REPLIES 4
1769 Views, 4 Replies
How does one programmatically set the command line to have keyboard focus?
I'm programmatically setting an active/focused PaletteSet's visibility to false.
_paletteSet.Visible = false;
I would like to follow this line with code that sets the command line to receive focus.
The PaletteSet for other reasons has KeepFocus = true.
Thanks!
I've tried various Win32 APIs (SwitchToThisWindow, SetForegroundWindow, SetActiveWindow) to no avail.  I also tried SendCommand() and SendStringToExecute(activate=true,..) , etc.
I imagine there's a way to do this with the native APIs.
Any ideas?  THANKS
Thanks!
Any ideas?  THANKS
4 REPLIES 4
fieldguy
fieldguy
Try this.
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt()
Try this.
in reply to: fieldguy
Thanks...but the command-line still isn't getting the focus.
fieldguy
fieldguy
Can you set keepfocus to false before visble = false?  When you show the palette again, set keepfocus to true.
I don't understand why you would keep focus on a palette that is not visible.
Can you post some code we can try?
joantopo
joantopo
I do this:
   Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
Paletteset lose focus and you can write in command line.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
I do this:
AutoCAD Inside the Factory
