how to draw line using winforms? getting System.Windows.Data Error: 40 : BindingExpression path error:
Maltezc
Maltezc
Hi all, I'm trying to draw a simple line using a WinForms button however it's not showing up on in model space once the button is clicked & the WinForms dialog is closed. I am able to draw a line in the command method but when I try the same approach using Winforms, it doesn't work. Autocad doesn't crash or anything, it just doesn't draw the line in model space and shows this in the debug:
System.Windows.Data Error: 40 : BindingExpression path error: 'Text' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=Text; DataItem='String' (HashCode=807563310); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsEnabled' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=IsEnabled; DataItem='String' (HashCode=807563310); target element is 'Border' (Name=''); target property is 'IsEnabled' (type 'Boolean')
System.Windows.Data Error: 40 : BindingExpression path error: 'ToolTipResolver' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=ToolTipResolver; DataItem='String' (HashCode=807563310); target element is 'Border' (Name='mBorder'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'ShowToolTipOnDisabled' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=ShowToolTipOnDisabled; DataItem='String' (HashCode=807563310); target element is 'Border' (Name='mBorder'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'ShowToolTipOnDisabled' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=ShowToolTipOnDisabled; DataItem='String' (HashCode=807563310); target element is 'Border' (Name='mBorder'); target property is 'ShowOnDisabled' (type 'Boolean')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsVisible' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=IsVisible; DataItem='String' (HashCode=807563310); target element is 'Border' (Name='mBorder'); target property is 'Visibility' (type 'Visibility')
System.Windows.Data Error: 40 : BindingExpression path error: 'ShowImage' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=ShowImage; DataItem='String' (HashCode=807563310); target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Image' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=Image; DataItem='String' (HashCode=807563310); target element is 'ComboBoxItemImage' (Name=''); target property is 'Source' (type 'ImageSource')
System.Windows.Data Error: 40 : BindingExpression path error: 'LargeImage' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=LargeImage; DataItem='String' (HashCode=807563310); target element is 'ComboBoxItemImage' (Name='mImage'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Image' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=Image; DataItem='String' (HashCode=807563310); target element is 'ComboBoxItemImage' (Name='mImage'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Image' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=Image; DataItem='String' (HashCode=807563310); target element is 'ComboBoxItemImage' (Name='mImage'); target property is 'Source' (type 'ImageSource')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''String' (HashCode=807563310)'. BindingExpression:Path=Id; DataItem='String' (HashCode=807563310); target element is 'ComboBoxItemText' (Name=''); target property is 'AutomationId' (type 'String')
here is my code:
**class1.cs**
        [CommandMethod("ACADPipe")]
        public static void pipe()
            // Get the current document and database, and start a transaction
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database acCurDb = doc.Database;
            using (Transaction tr = acCurDb.TransactionManager.StartTransaction())
                Form1 form1 = new Form1();
                form1.ShowDialog();
 **Form1.cs**
private void drawTestLine_Click(object sender, EventArgs e)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                BlockTable acBlkTbl = tr.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord acBlkTblRec2 = tr.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                Line line1 = new Line(new Point3d(0, 0, 0), new Point3d(100, 100, 0));
                line1.SetDatabaseDefaults();
                acBlkTblRec2.AppendEntity(line1);
                tr.AddNewlyCreatedDBObject(line1, true);
                tr.Commit();
All help / direction is appreciated.
norman.yuan
I guess it is the error message that seems having nothing to do with Win Form makes people hesitate to response to your question. The error message looks like somehow related to WPF UI. Also, when you say "... show this in debug", what does "debug" mean? where exactly do you see the error message? A pop-up window in AutoCAD, where you can click either "Detail" to see more error message, or "Continue", which would either let AutoCAD continue. if the error is not that fatal, or let AutoCAD die?
Anyway, if your Form1 is a true win form, regardless the strange error, your code in the CommandMethod is very wrong, in 2 ways:
1. You DO NOT show dialog form (modal view) with Form.ShowDialog() in AutoCAD .NET API add-in. You must use AutoCAD .NET API method
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog[Window]()
2. You DO NOT sandwich all the code (showing the dialog box, and then user may do something to AutoCAD by interacting with the form) with a Transaction and only not commit it (which means whatever user does to AutoCAD would be aborted when you close the dialog form. That is why the line drawn by the button clicking action is not there: it is lost after you close the form. because the outer-most transaction is not commited (thus, aborted automatically).
While letting UI's event handler (button clicking, in your case) directly interact with AutoCAD isn't a very good code practice, I think you can live with that for now (as beginner?), thus, the simple fix to your code is to modify the CommandMethed as following:
            using (Form1 form1 = new Form1())
                Application.ShowModalDialog(form1);
And, in your drawTestLine_Click() method, you might want to add
ed.UpdateScreen()
at the end of the Transaction, if you want the newly created line to be seen without dismissing the dialog box.
Norman Yuan
Drive CAD With Code
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
