Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
.NET
Getting and sorting ATRIBUTE TEXTs in the block and divide
0 REPLIES 0
Message 1 of 1
k005
102 Views, 0 Replies
Hello friends;
Blok reference ( attribute text )
2x15ø14/200 L=1550
10ø12/200 L=1500
5ø12 L=150
I have Value values ​​in the POZYAZI tag in block references such as. I want to divide these into /xxx and L=xxx 10 and print them as a text object, one under the other, as a list in a new format. However, I cannot access the value in POZYAZI. Where am I making a mistake?
Thanks in advance to my helpful friend.
wanted: ( text object)
2x15ø14/20 L=155
10ø12/20 L=150
5ø12 L=15
 [CommandMethod("ProcessPozyazi")]
 public void ProcessPozyazi()
     Document doc = Application.DocumentManager.MdiActiveDocument;
     Database db = doc.Database;
     Editor ed = doc.Editor;
     using (Transaction tr = db.TransactionManager.StartTransaction())
         // Select block references with attributes
         PromptSelectionResult selRes = ed.GetSelection(new PromptSelectionOptions(), new SelectionFilter(new TypedValue[] { new TypedValue((int)DxfCode.Start, "INSERT") }));
         if (selRes.Status != PromptStatus.OK) return;
         SelectionSet selSet = selRes.Value;
         List<string> outputList = new List<string>();
         foreach (SelectedObject selObj in selSet)
             if (selObj != null)
                 BlockReference blockRef = tr.GetObject(selObj.ObjectId, OpenMode.ForRead) as BlockReference;
                 if (blockRef != null)
                     foreach (ObjectId attId in blockRef.AttributeCollection)
                         AttributeReference attRef = tr.GetObject(attId, OpenMode.ForRead) as AttributeReference;
                         if (attRef != null && attRef.Tag == "POZYAZI")
                             string pozyaziValue = attRef.TextString;
                             string[] parts = pozyaziValue.Split(' ');
                             if (parts.Length > 2)
                                 string[] sizeParts = parts[1].Split('/');
                                 string[] diamSpacingParts = sizeParts[0].Split('ø');
                                 string adet = parts[0];
                                 string cap = diamSpacingParts[0];
                                 string uzunluk = parts[3].Substring(2); // "L="'den sonraki kısmı al
                                 string aralik = sizeParts[1];
                                 string length = parts[5];
                                 outputList.Add($"{adet} {cap}ø{aralik}/{uzunluk} L={length}");
         tr.Commit();
         if (outputList.Count == 0)
             ed.WriteMessage("\nNo valid POZYAZI attributes found.");
             return;
         PromptPointResult ppr = ed.GetPoint("Select a point to start writing text: ");
         if (ppr.Status != PromptStatus.OK) return;
         Point3d startPoint = ppr.Value;
         using (Transaction writeTr = db.TransactionManager.StartTransaction())
             BlockTable bt = writeTr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
             BlockTableRecord btr = writeTr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
             double textHeight = 2.5;
             double lineSpacing = textHeight * 1.5;
             Point3d currentPoint = startPoint;
             foreach (var line in outputList)
                 DBText text = new DBText
                     Position = currentPoint,
                     Height = textHeight,
                     TextString = line,
                     TextStyleId = db.Textstyle
                 btr.AppendEntity(text);
                 writeTr.AddNewlyCreatedDBObject(text, true);
                 currentPoint = new Point3d(currentPoint.X, currentPoint.Y - lineSpacing, currentPoint.Z);
             writeTr.Commit();
0 REPLIES 0
AutoCAD Inside the Factory
