.NET
GetClosestPointTo Curve Extension
2 REPLIES 2
SRSDS
621 Views, 2 Replies
SRSDS
Can someone suggest the cleanest way to find the closest point to the extension of a curve.
Given that I know which end the extension is from.
If the closest point is the curve StartPoint I can easily get position on the curve at a distance of 1 from the StartPoint.
Create a line to find the extension.
 Dim EP As Point3d = TransformPointToLine(MousePosition, curve.StartPoint, curve.GetPointAtDist(1))
Function TransformPointToLine(ByVal apoint As Point3d, ByVal startpoint As Point3d, ByVal EndPoint As Point3d) As Point3d
    Using myline As Line = New Line(startpoint, EndPoint)
         Return myline.GetClosestPointTo(apoint, True)
    End Using
End Function
Can I do the same for the end point? Ie Find a point 1mm back from the curve EndPoint?
    End Using
End Function
2 REPLIES 2
_gile
in reply to: SRSDS
_gile
For geometric computations you should use the geometric objects from the Autodesk.AutoCAD.Geometry namespace, they are much more lighter than entities and do not need to be explicitly disposed.
        static Point3d TransformPointToLine(Point3d point, Point3d startPoint, Point3d endPoint)
            return new Line3d(startPoint, endPoint).GetClosestPointTo(point).Point;
Gilles Chanteau
GileCAD
GitHub
Gilles Chanteau
GileCAD
GitHub
_gile
in reply to: _gile
_gile
I didn't read your request enough attentively.
This should be closer to my understanding of your issue.
        static Point3d GetClosestPointToStartTangent(Curve curve, Point3d point)
            var line = new Line3d(curve.StartPoint, curve.GetFirstDerivative(curve.StartPoint));
            return line.GetClosestPointTo(point).Point;
        static Point3d GetClosestPointToEndtTangent(Curve curve, Point3d point)
            var line = new Line3d(curve.EndPoint, curve.GetFirstDerivative(curve.EndPoint));
Gilles Chanteau
GileCAD
GitHub
Gilles Chanteau
GileCAD
GitHub
AutoCAD Inside the Factory
