Get properties and place them into an attribute block
hmsnake
Message 1 of 9
hmsnake
Hello, I am attacking a very ambitious project right now. I want to create a C# (.NET) command that:
1. I want to insert an attribute block into a layout. The user should be able to choose a DWG file that the attribute lives in with the file explorer. Give the user the option to insert into the current layout or into every layout within a SSM
2. I want it to get all of the properties from the layout and the SSM it is part of.
3. The name of each property (i.e. Totsheet) matches corresponds to a prompt in the attribute block. It should identify the prompt name and then insert the property gotten:
I started by trying to achieve each goal individually (see below) and they work. They are slightly simpler versions, but I figured I could ramp them up when the time came. I used Audrey Bushman's code to access the SSM because I could not figure it out myself. I am using ChatGPT to help as well since I am not familiar with the API.
My problems are:
1. I cant get the layout properties, only the SSM properties.
2. I can replace things within an attribute, but not the way I want to. The code that I've pieced together takes a string in from the user, then replaces all of the attributes with that string. I havent figured out any other attribute replacements that will work.
if this is impossible i will be sad but not surprised.. thank you all in advance
Replies (8)
Message 2 of 9
Ed__Jobe
Please post  your code to a code window.
Ed
How to post your code.
Message 3 of 9
hmsnake
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Forms;
public class InsertExternalBlock
    [CommandMethod("InsertExtBlock")]
    public void InsertBlockFromExternalFile()
        // Get the current document and editor
        Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
        Editor ed = doc.Editor;
        // Prompt user to select a DWG file to insert as a block
        OpenFileDialog openFileDialog = new OpenFileDialog
            Filter = "DWG Files (*.dwg)|*.dwg",
            Title = "Select the DWG File to Insert as a Block"
        if (openFileDialog.ShowDialog() != DialogResult.OK)
            ed.WriteMessage("\nOperation cancelled.");
            return;
        string dwgFilePath = openFileDialog.FileName;
        // Run the AutoCAD INSERT command to insert the DWG as a block
        ed.Command("_.-INSERT", dwgFilePath, "0,0,0", "1", "1", "0");
using System;
using Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(YourNamespace.UpdateBlockAttributesCommand))]
namespace YourNamespace
    public class UpdateBlockAttributesCommand : IExtensionApplication
        public void Initialize() { }
        public void Terminate() { }
        [CommandMethod("UpdateBlockAttributes")]
        public void UpdateBlockAttributes()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            // Prompt user to enter the string
            PromptStringOptions promptStringOptions = new PromptStringOptions("\nEnter the string to insert into the block attributes: ");
            PromptResult promptResult = ed.GetString(promptStringOptions);
            if (promptResult.Status != PromptStatus.OK)
                ed.WriteMessage("\nOperation canceled.");
                return;
            string userInput = promptResult.StringResult;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                // Iterate through all block references in the drawing
                BlockTable blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                foreach (ObjectId blockId in blockTable)
                    BlockTableRecord blockRecord = (BlockTableRecord)tr.GetObject(blockId, OpenMode.ForRead);
                    // Check if block name contains "Attrib"
                    if (blockRecord.Name.Contains("Attrib"))
                        // Iterate through all block references in the current space (ModelSpace or PaperSpace)
                        BlockTableRecord currentSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        foreach (ObjectId entityId in currentSpace)
                            Entity entity = (Entity)tr.GetObject(entityId, OpenMode.ForRead);
                            if (entity is BlockReference blockRef)
                                // Check if the block reference matches the desired block
                                if (blockRef.Name.Equals(blockRecord.Name, StringComparison.OrdinalIgnoreCase))
                                    foreach (ObjectId attId in blockRef.AttributeCollection)
                                        AttributeReference attRef = (AttributeReference)tr.GetObject(attId, OpenMode.ForWrite);
                                        attRef.TextString = userInput;
                tr.Commit();
            ed.WriteMessage("\nAttributes updated for blocks with 'Attrib' in their name.");
using System;
using System.Text;
using System.Windows.Forms; // For MessageBox
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Rtm = Autodesk.AutoCAD.Runtime;
using Comp = ACSMCOMPONENTS24Lib;
using Autodesk.Civil.DatabaseServices;
[assembly: Rtm.ExtensionApplication(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
[assembly: Rtm.CommandClass(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
namespace Bushman.AutoCAD.SheetSetTools
    public class SheetSetCommands : Rtm.IExtensionApplication
        const string ns = "bush"; // namespace
        [Rtm.CommandMethod(ns, "ss-get-properties", Rtm.CommandFlags.Modal)]
        public void GetSheetSetProperties()
            App.Document doc = cad.DocumentManager.MdiActiveDocument;
            Db.Database db = doc.Database;
            Ed.Editor ed = doc.Editor;
            Comp.AcSmSheetSetMgr mng = new Comp.AcSmSheetSetMgr();
            Comp.IAcSmEnumDatabase enumerator = mng.GetDatabaseEnumerator();
            enumerator.Reset();
            Comp.AcSmDatabase smDb = enumerator.Next();
            if (smDb != null)
                try
                    smDb.LockDb(db);
                    Comp.AcSmSheetSet sheetset = smDb.GetSheetSet();
                    if (sheetset != null)
                        StringBuilder sb = new StringBuilder();
                        sb.AppendLine($"Sheet Set Name: {sheetset.GetName()}");
                        sb.AppendLine($"Description: {sheetset.GetDesc()}");
                        // Retrieve custom properties
                        Comp.AcSmCustomPropertyBag customProperties = sheetset.GetCustomPropertyBag();
                        if (customProperties != null)
                            // List of desired custom property names
                            string[] desiredProperties = new string[]
                                "Project Name",
                                "Project Number",
                                "Issued Date:",
                                "Title1",
                                "Title2",
                                "Title3",
                                "TotSheets"
                            // Iterate through desired properties
                            foreach (var propertyName in desiredProperties)
                                try
                                    var property = customProperties.GetProperty(propertyName) as Comp.AcSmCustomPropertyValue;
                                    if (property != null)
                                        sb.AppendLine($"{propertyName}: {property.GetValue()}");
                                    else
                                        sb.AppendLine($"{propertyName}: [Not Found]");
                                catch (Exception ex)
                                    sb.AppendLine($"{propertyName}: Error retrieving value - {ex.Message}");
                        else
                            sb.AppendLine("No custom properties found.");
                        // Display the properties in a message box
                        MessageBox.Show(sb.ToString(), "Sheet Set Properties");
                    else
                        ed.WriteMessage("\nNo sheet set is available.");
                    ed.WriteMessage($"\nError: {ex.Message}");
                finally
                    smDb.UnlockDb(db, true);
            else
                ed.WriteMessage("\nNo sheet set is open.");
        private string GetCustomPropertyValue(Comp.AcSmCustomPropertyBag customProperties, string propertyName)
            try
                    return property.GetValue();
                // Log or handle the exception if needed
                Console.WriteLine($"Error retrieving custom property {propertyName} - {ex.Message}");
            return null;
            ed.WriteMessage("\nSheetSetTools. © Andrey Bushman, 2013\n\n");
            // Empty body.
Message 4 of 9
Ed__Jobe
If I get more time, I might be able to add more, but here's an extension method that will help.
BTW, I think it's Andrey, not Audrey.
        //InsertBlockReference
        /// <summary>
        /// Insert a block into the current space. You can optionally fill attribute values.
        /// </summary>
        /// <param name="target">The BlockTableRecord of the (model/paper) space to insert the block in.</param>
        /// <param name="blkName">A string of the block's name.</param>
        /// <param name="insertPoint">A Point3d to be used as the insertion point.</param>
        /// <param name="attValues">A Dictionary&gtstring, string&lt in the form of Key, value.
        /// To be used to supply tag string values. If a key is not found for an attribute,
        /// the value from the AttributeDefinition is used.</param>
        /// <returns><see cref="Autodesk.AutoCAD.DatabaseServices.BlockReference"/> of the inserted block.</returns>
        public static BlockReference InsertBlockReference(
                                        this BlockTableRecord target,
                                        string blkName,
                                        Point3d insertPoint,
                                        Dictionary<string, string> attValues = null)
            if (target == null)
                throw new ArgumentNullException("target");
            Database db = target.Database;
            Transaction tr = db.TransactionManager.TopTransaction ?? throw new AcRx.Exception(ErrorStatus.NoActiveTransactions);
            BlockReference br = null;
            BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
            ObjectId btrId = bt.GetBlock(blkName);
            if (btrId != ObjectId.Null)
                br = new BlockReference(insertPoint, btrId);
                _ = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead);
                target.AppendEntity(br);
                tr.AddNewlyCreatedDBObject(br, true);
                br.AddAttributeReferences(attValues);
            return br;
Ed
Message 5 of 9
hmsnake
Oh my gosh you are so right🖐 I will play around with this, thank you! If you have any information on accessing layout properties (within the same sheet set manage) that would be much appreciated as well!
Message 6 of 9
ActivistInvestor
That's not a method of BlockReference, so it must be an an extension method that comes from the same source as the rest of the code.
Message 7 of 9
Ed__Jobe
Yes, thanks.
        /// <summary>
        /// Extension method that returns adds <see cref="AttributeReference"/>'s to a <see cref="BlockReference"/>.
        /// AttributeReference values are taken from the Dictionary attValues argument.
        /// </summary>
        /// <param name="target">A BlockReference to add the AttributeReferences to.</param>
        /// <param name="attValues">The Dictionary to get attribute values from.
        /// The first string is the Key and is equal to the AttributeDefinition.Tagstring.
        /// The second string is the attribute value.</param>
        /// <returns>Void.</returns>
        public static void AddAttributeReferences(this BlockReference target, Dictionary<string, string> attValues)
            if (target == null)
            Transaction tr = target.Database.TransactionManager.TopTransaction ?? throw new AcRx.Exception(ErrorStatus.NoActiveTransactions);
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(target.BlockTableRecord, OpenMode.ForRead);
            foreach (AttributeDefinition attDef in btr.AttributeDefinitions(tr))
                if (!attDef.Constant)
                    AttributeReference attRef = new AttributeReference();
                    attRef.SetAttributeFromBlock(attDef, target.BlockTransform);
                    if (attValues != null && attValues.ContainsKey(attDef.Tag.ToUpper()))
                        attRef.TextString = attValues[attDef.Tag.ToUpper()];
                    target.AttributeCollection.AppendAttribute(attRef);
                    tr.AddNewlyCreatedDBObject(attRef, true);
        /// <summary>
        /// Extension method that returns a <see cref="Collection"/> of <see cref="AttributeDefinition"/>'s from a <see cref="BlockTableRecord"/>.
        /// </summary>
        /// <param name="btr">This BlockTableRecord to use.</param>
        /// <param name="trans">The Transaction within which to pass the Collection of AttributeDefinitions.</param>
        /// <returns>A Collection of AttributeDefinitions.</returns>
        public static Collection<AttributeDefinition> AttributeDefinitions(this BlockTableRecord btr, Transaction trans)
            Collection<AttributeDefinition> atts = new Collection<AttributeDefinition>();
            RXClass theClass = RXObject.GetClass(typeof(AttributeDefinition));
            // Loop through the entities in model space
            foreach (ObjectId objectId in btr.Cast<ObjectId>())
                // Look for entities of the correct type
                if (objectId.ObjectClass.IsDerivedFrom(theClass))
                    AttributeDefinition attd = objectId.OpenAs<AttributeDefinition>(trans);
                    atts.Add(attd);
            return atts;
Ed
Message 8 of 9
ActivistInvestor
The reason I put code on GitHub is because of this very problem - I can't afford to take the time to find and add all of the code which the code I'm sharing is dependent on, and in some cases, the dependencies can be half-a-dozen layers deep.
I don't write code that can exist in a vacuum (the way coding examples are written), because that's totally unacceptable for real-world application development . So, sharing snippets of code or individual methods is very difficult, as very little of the code I've written over the years can exist or work in a vacuum, without any dependence on other custom-developed code.
If you're sharing your code, you can post it in a GitHub repository along with all of the code it's dependent on, and then just share a link to it, and you don't need to worry about finding out and adding what's missing.
Message 9 of 9
Ed__Jobe
Yes, that's a good idea. I've only recently gotten access to GitHub here at work and I've been starting to do that.
Ed
