Get an offset polyline
youssefGC
youssefGC
Hi everyone,
I try to write the code below, in order to sweep and offset each segment in a given polyline (prompt by user). But when I execute them in the example (image), I found a "System.ArgumentOutOfRangeException"  in the second part.
for (int i = 0; i < nbrOfSegment; i++)
                    // create a single pline
                    Polyline ProvisoirPline = new Polyline();
                    ProvisoirPline.AddVertexAt(ProvisoirPline.NumberOfVertices, OriginalPline.GetPoint2dAt(i), OriginalPline.GetBulgeAt(i), 0, 0);
                    ProvisoirPline.AddVertexAt(ProvisoirPline.NumberOfVertices, OriginalPline.GetPoint2dAt(i + 1), OriginalPline.GetBulgeAt(i + 1), 0, 0);
                    DBObjectCollection DBObj = ProvisoirPline.GetOffsetCurves(10);
                    Polyline NewOffsetSegment = (Polyline)dbo[0]; // Argument Out Of Range Exception
                    /// code
Thank you.
norman.yuan
Shouldn't this line
be
Polyline NewOffsetSegment = (Polyline)DBObj[0];
it looks like variable "dbo" is declared before the showed code and is an empty collection of something.
Norman Yuan
Drive CAD With Code
youssefGC
Thanks for your reply.
Yes I fall into an error, the variable "dbo" should be "DBObj".
I found the origin of the problem : the offset value is greater than the diameter of the arc (when the offset direction was inside the polyline), but when I reduce the value of the offset the code march perfectly.
