Sweep and polyline path direction
E3DE
E3DE
I noticed that invert polyline (path of sweep) vertex direction change the behaviour of sweep command: the extrusion changes "indide" or "outside" the path.
I use this code to create a sweep:
Sweep
To do this by code I need to invert the direction of polyline or there is an option to say "do sweep on the contrary". If not how to invert polyline vertex by code?
Thank you
Andrea
_gile
What about using the Curve.ReverseCurve method ?
Gilles Chanteau
GileCAD
GitHub
E3DE
I didn't know this method. Thank you!
