General Rules of Try..Catch
SRSDS
SRSDS
I'm using Try.. Catch error handlers at the start and end of subroutines but often errors aren't catched.
A simple example is if array(i) throws an exception
'array(i)' threw an exception of type 'System.IndexOutOfRangeException'
Do I need to put Try.. Catch in intermediate sections of SubRoutines?
Are there any rules to follow?
ActivistInvestor
Can you show an example of where try and catch does't trap an IndexOutOfRange exception?
norman.yuan
In AutoCAD .NET API, we do run into cases from time to time where AutoCAD crashes even the code that causes the exception is wrapped in try...catch... block, but they usually happens with specific AutoCAD operation with abnormal situation, such as corrupted drawing file, or handling AutoCAD object in wrong way. It depends on how the .NET API wrapped the underline ObjectARX stuff.
But saying try...catch... does not catching array's IndexOutOfRange exception? I can only assume something very unusual with your code.
Here is simplified code to raise and handle array's IndexOutRange exception that works correctly, as expected:
using Autodesk.AutoCAD.Runtime;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(MiscTest.MyCommands))]
namespace MiscTest
    public class MyCommands
        [CommandMethod("CatchError1")]
        public static void CatchErrorFromOutside()
            var dwg = CadApp.DocumentManager.MdiActiveDocument;
            var ed = dwg.Editor;
            try
                RaiseArrayOutOfRangeException();
            catch (System.Exception ex)
                CadApp.ShowAlertDialog($"Error caught from outside routine:\n{ex.Message}");
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        [CommandMethod("CatchError2")]
        public static void CatchErrorFromInside()
            try
                CatchArrayOutOfRangeExceptionFromInsideRoutine();
                //This "catch..." clause should not be executed
                CadApp.ShowAlertDialog($"Unhandled error from inside:\n{ex.Message}");
            finally
        private static void RaiseArrayOutOfRangeException()
            var numbers = new int[] { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 };
            for (int i=0; i<=20; i++)
                //When i>9, an "Out of range" exception will be raised
                string val = numbers[i].ToString();
        private static void CatchArrayOutOfRangeExceptionFromInsideRoutine()
            try
                CadApp.ShowAlertDialog($"Error caught from inside routine:\n{ex.Message}");
You may want to post your code to back up your claim.
Norman Yuan
Drive CAD With Code
