the folwing code to create a table in AutoCAD for points positions P#,E,N,Z
I need to format the table throw code because the result is the same picture attach
public void CreateTableFormula()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction Tx = db.TransactionManager.StartTransaction())
ObjectId ModelSpaceId =
SymbolUtilityServices.GetBlockModelSpaceId(db);
BlockTable bt = Tx.GetObject(db.BlockTableId,
OpenMode.ForRead) as BlockTable;
BlockTableRecord btr = Tx.GetObject(ModelSpaceId,
OpenMode.ForWrite) as BlockTableRecord;
TypedValue[] tv = new TypedValue[1];
List<Point3d> lspl = new List<Point3d>();
int number = 1;
tv.SetValue(new TypedValue((int)DxfCode.Start, "point"), 0);
SelectionFilter filter = new SelectionFilter(tv);
PromptSelectionResult ssPrompt;
ssPrompt = ed.GetSelection(filter);
if (ssPrompt.Status == PromptStatus.OK)
SelectionSet ss = ssPrompt.Value;
foreach (SelectedObject sObj in ss)
DBPoint spoint = Tx.GetObject(sObj.ObjectId, OpenMode.ForWrite) as DBPoint;
lspl.Add(spoint.Position);
PromptPointOptions ppo = new
PromptPointOptions("\nSpecify insertion point: ");
PromptPointResult ppr = ed.GetPoint(ppo);
if (ppr.Status != PromptStatus.OK)
return;
double rowHeight = 5, colWidth = 7;
Table table = new Table();
table.Position = ppr.Value;
table.Cells[0, 0].Value = "saber Title";
table.Cells[0, 0].Alignment = CellAlignment.MiddleCenter;
table.Cells[0, 0].GetMergeRange();
table.Cells[0, 0].TextHeight = 2;
table.InsertColumns(0, colWidth, 3);
table.InsertRows(0, rowHeight, 1);
//table.Alignment = CellAlignment.MiddleCenter;
table.Cells.Alignment = CellAlignment.MiddleCenter;
table.Cells[1, 0].Value = "P#";
table.Cells[1, 1].Value = "E";
table.Cells[1, 2].Value = "N";
table.Cells[1, 3].Value = "Z";
//table.Cells[1, 4].Value = "D";
int InsertRow = 2;
foreach (Point3d pt3 in lspl)
DBText txt = new DBText();
txt.SetDatabaseDefaults();
txt.TextString = number.ToString();
txt.Position = pt3;
txt.Rotation = 0;
txt.Height = 1.8;
btr.AppendEntity(txt);
Tx.AddNewlyCreatedDBObject(txt, true);
table.InsertRows(InsertRow, rowHeight, 1);
table.Cells[InsertRow, 0].TextString = number.ToString();
table.Cells[InsertRow, 1].TextString = $@"{txt.Position.X: 0.0000}";
table.Cells[InsertRow, 2].TextString = $@"{txt.Position.Y: 0.0000}";
table.Cells[InsertRow, 3].TextString = $@"{txt.Position.Z: 0.0000}";
number++;
InsertRow++;
btr.AppendEntity(table);
Tx.AddNewlyCreatedDBObject(table, true);
Tx.Commit();
