.NET
Finding the AutoCAd Application folder using VB.Net
8 REPLIES 8
Message 1 of 9
GeeHaa
3579 Views, 8 Replies
Is there a way to find the AutoCAD Application folder when AutoCAD is not running? I need to copy an ACADDoc.lsp file to the support folder on Installs.
8 REPLIES 8
Message 2 of 9
_gile
in reply to: GeeHaa
You can get it via the registry.
Look for the 'AcadLocation' value in the 'HKLM\SOFTWARE\Autodesk\AutoCAD\R20.0\ACAD-E001:409' key.
This path may differ according to the AutoCAD version but you can get it from the HKCU\Software\Autodesk\AutoCAD\<CurVer value>\<Curver value>.
        // Get the AutoCAD current version registry key
        private static string GetAcadCurVerKey()
            StringBuilder sb = new StringBuilder(@"Software\Autodesk\AutoCAD\");
            using (RegistryKey acad = Registry.CurrentUser.OpenSubKey(sb.ToString()))
                sb.Append(acad.GetValue("CurVer")).Append(@"\");
                using (RegistryKey curVer = Registry.CurrentUser.OpenSubKey(sb.ToString()))
                    return sb.Append(curVer.GetValue("CurVer")).ToString();
        // Get the acad.exe location for the AutoCAD current version
        private static string GetAcadLocation()
            using (RegistryKey rk = Registry.LocalMachine.OpenSubKey(GetAcadCurVerKey()))
                return (string)rk.GetValue("AcadLocation");
Gilles Chanteau
GileCAD
GitHub
Message 3 of 9
_gile
in reply to: _gile
Maybe this is more readable.
C#
public string GetAcadCurVerKey()
    RegistryKey rkcu = Registry.CurrentUser;
    string path = @"Software\Autodesk\AutoCAD\";
    using (RegistryKey rk1 = rkcu.OpenSubKey(path))
        path += rk1.GetValue("CurVer");
        using (RegistryKey rk2 = rkcu.OpenSubKey(path))
            return path + "\\" + rk2.GetValue("CurVer");
public string GetAcadLocation()
    RegistryKey rklm = Registry.LocalMachine;
    string path = GetAcadCurVerKey();
    using (RegistryKey rk = rklm.OpenSubKey(path))
VB
' Get the AutoCAD current version registry key
Private Function GetAcadCurVerKey() As String
    Dim rkcu As RegistryKey = Registry.CurrentUser
    Dim path As String = "Software\Autodesk\AutoCAD\"
    Using rk1 As RegistryKey = rkcu.OpenSubKey(path)
        Using rk2 As RegistryKey = rkcu.OpenSubKey(path)
            Return path & "\" & rk2.GetValue("CurVer")
        End Using
    End Using
End Function
' Get the acad.exe location for the AutoCAD current version
Private Function GetAcadLocation() As String
    Dim rklm As RegistryKey = Registry.LocalMachine
    Dim path As String = GetAcadCurVerKey()
    Using rk As RegistryKey = rklm.OpenSubKey(path)
        Return DirectCast(rk.GetValue("AcadLocation"), String)
    End Using
End Function
Gilles Chanteau
GileCAD
GitHub
Message 4 of 9
GeeHaa
in reply to: GeeHaa
Thanks Very Much this works perfectly.
Message 5 of 9
Jedimaster
in reply to: GeeHaa
If you do not want to have to open up the registry
Dim objapp As Object = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
objapp.path
appears to work
Message 6 of 9
GeeHaa
in reply to: Jedimaster
I like that better.
Message 7 of 9
kdub_nz
in reply to: GeeHaa
GeeHaa wrote:
I like that better.
GeeHaa,
that code requires AutoCAD to be running, which is contrary to the request in your original post.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
Sometimes the question is more important than the answer.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 8 of 9
GeeHaa
in reply to: kdub_nz
Its been so long ago I forgot I was using it in an installer that runs outside of AutoCAD. You are correct.
Message 9 of 9
in reply to: GeeHaa
I had to change one line in order for windows to find the entire registry path
RegistryKey rklm = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, RegistryView.Registry64);
AutoCAD Inside the Factory
