To all,
I am trying to write a .NET add-in to select a 3D solid and a line (where one endpoint of the line lies on a face of the solid). The add-in will then extrude the face in which the endpoint lies, using the line as the path of extrusion. See starting conditions in picture:
My code in its current form is below. But it is not currently working. I have been scratching my head over this one for awhile, any ideas?
Thanks in advance for any help,
Will
Acad 2009, VB Express 2008
Imports System Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.BoundaryRepresentation Imports BrFace = Autodesk.AutoCAD.BoundaryRepresentation.Face <Assembly: CommandClass(GetType(Autodesk.AutoCAD.ExtrudeFace.SOMRClass))> Namespace Autodesk.AutoCAD.ExtrudeFace Public Class SOMRClass <CommandMethod("exf")> _ Public Sub ExtrudeFace() Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Dim acDocEd As Editor = acDoc.Editor 'set up prompt selection options Dim acPromptEntOpt1 As PromptEntityOptions = New PromptEntityOptions("") acPromptEntOpt1.Message = vbLf & "Select a 3D Solid: " acPromptEntOpt1.SetRejectMessage(vbLf & "Select a 3D Solid only!") acPromptEntOpt1.AddAllowedClass(GetType(Solid3d), True) 'ask the user to select the 3d solid Dim acPromptEntRes1 As PromptEntityResult = acDocEd.GetEntity(acPromptEntOpt1) If acPromptEntRes1.Status = PromptStatus.OK Then 'set up prompt selection options Dim acPromptEntOpt2 As PromptEntityOptions = New PromptEntityOptions("") acPromptEntOpt2.Message = vbLf & "Select the path of extrusion: " acPromptEntOpt2.SetRejectMessage(vbLf & "Select a line only!") acPromptEntOpt2.AddAllowedClass(GetType(Line), True) 'ask the user to select the path of extrusion Dim acPromptEntRes2 As PromptEntityResult = acDocEd.GetEntity(acPromptEntOpt2) If acPromptEntRes2.Status = PromptStatus.OK Then Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Try 'get the solid Dim acSolid As Solid3d = acTrans.GetObject(acPromptEntRes1.ObjectId, OpenMode.ForRead) 'get the line Dim acLine As Line = acTrans.GetObject(acPromptEntRes2.ObjectId, OpenMode.ForRead) 'get the startpoint of the line Dim acStartPt As Point3d = acLine.StartPoint 'get the end point of the line Dim acEndPt As Point3d = acLine.EndPoint 'convert the line to a curve Dim acCurve As Curve = TryCast(acLine, Curve) If acCurve <> Nothing Then 'Build the BRep topology object to traverse Using acBrep As Brep = New Brep(acSolid) Dim acFaceColl As BrepFaceCollection = acBrep.Faces For Each acFace As BrFace In acFaceColl 'test to see if either point lies on the face Dim ContainmentVal1 As PointContainment = New PointContainment() acFace.GetPointContainment(acStartPt, ContainmentVal1) Dim ContainmentVal2 As PointContainment = New PointContainment() acFace.GetPointContainment(acEndPt, ContainmentVal2) 'if the point lies on the face, then extrude the face If ContainmentVal1 = PointContainment.Inside Or ContainmentVal2 = PointContainment.Inside Then 'extrude the face, this line throws an exception Dim FaceSubEntIds() As SubentityId = New SubentityId() {acFace.SubentityPath.SubentId} acSolid.ExtrudeFacesAlongPath(FaceSubEntIds, acCurve) End If Next End Using End If Catch ex As System.Exception acDocEd.WriteMessage(vbLf & "Exception: " & ex.Message) End Try 'commit the transaction acTrans.Commit() End Using End If End If End Sub End Class End Namespace
