Extra Layer Names When Importing a Layout From a Template
mgorecki
mgorecki
When I manually add a new layout from a template, I do NOT get any extra layers, but when I use VB to do the same thing, I get extra layers.
In the original drawing, I have layers called "SHEET", "TEXT", and "VIEWPORT" (among other layers).
In the template where I get my new layout, I also have the same layer names ("SHEET", "TEXT", and "VIEWPORT").
After the new layout gets read in, I now have extra layers called "$0$SHEET", "$0$TEXT", and "$0$VIEWPORT".  Why does this happen using VB, but not when I do it manually?  Is there anything I can do to the code to change this?  I understand the layer names are the same, but they're the same whether I do it manually or by code.
    Public Function importLayout(ByVal templateFileName As String, ByVal templateLayoutName As String) As ObjectId
        Dim idLayout As ObjectId = ObjectId.Null
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim oLock As DocumentLock = doc.LockDocument()
        Dim dbSource As New Database(False, False)
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim templateTrans As Transaction = db.TransactionManager.StartTransaction()
        Try
            dbSource.ReadDwgFile(templateFileName, System.IO.FileShare.Read, True, Nothing)
            Dim idDbdSource As ObjectId = dbSource.LayoutDictionaryId
            Dim layoutDictionary As DBDictionary = DirectCast(templateTrans.GetObject(idDbdSource, OpenMode.ForRead, False, False), DBDictionary)
            For Each deLayout As DictionaryEntry In layoutDictionary
                Dim sLayout As String = deLayout.Key.ToString()
                If sLayout.ToUpper() = templateLayoutName.ToUpper() Then
                    idLayout = DirectCast(deLayout.Value, ObjectId)
                    Exit For
                End If
            Next
            If idLayout <> ObjectId.Null Then
                Dim idc As New ObjectIdCollection()
                idc.Add(idLayout)
                Dim idMap As IdMapping = New IdMapping()
                Dim dbdict As DBDictionary = DirectCast(templateTrans.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, False, False), DBDictionary)
                dbdict.UpgradeOpen()
                db.WblockCloneObjects(idc, db.LayoutDictionaryId, idMap, DuplicateRecordCloning.MangleName, False)
                Dim ip As IdPair = idMap.Lookup(idLayout)
                idLayout = ip.Value
                Dim layoutMgr As LayoutManager = LayoutManager.Current
                layoutMgr.CurrentLayout = templateLayoutName
                dbdict.DecomposeForSave(DwgVersion.Current)
                ed.Regen()
            End If
            templateTrans.Commit()
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            MsgBox(ex.StackTrace)
        Finally
            templateTrans.Dispose()
            dbSource.Dispose()
            oLock.Dispose()
        End Try
        Return idLayout
    End Function
Mark
Looking real quick at your WblockCloneObjects call your DuplicateRecordCloning argument is set to DuplicateRecordCloning.MangleName.
From docs
MangleName -  Mangle all the incoming record names using $0$
mgorecki
Hi Jeff,
Thank you very much for your help.  That did the trick.  Where can I find out info like this?  I looked in http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html, but I didn't see where it broke the command down to include the arguments.
Mark
Look inside the ObjectArx docs folder.
The arxmgd.chm is the .NET API but I would strongly suggest using the arxdoc.chm.
The arxdoc.chm contains the arxmgd.chm  but contains the ObjectARX developers guide that has alot of useful information to give some deeper explanations on what the .NET API in end is using.
mgorecki
Thanks for the info.  I've made a shortcut to it on my desktop.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
