Sorry i saw may topics regarding this, but nothing works for me.
I am trying to saveas each layout to a separate dwg and delete the other layouts from exported dwg file. Partially this code works. but for eg; if you have 3 layout in one dwg then it saveas 3 separate dwgs but other layouts are still there with layout name as layout1, layout2, layout3 etc. anyone help on this?
// Process selected files
foreach (string file in _selectedFiles)
using (Database db = new Database(false, true))
db.ReadDwgFile(file, FileOpenMode.OpenForReadAndAllShare, false, null);
using (Transaction tr = db.TransactionManager.StartTransaction())
try
ExportAllLayouts(file);
catch (System.Exception ex)
throw new System.Exception($"\nError exporting layouts: {ex.Message}", ex);
tr.Commit();
// Update progress
progress += progressStep;
progressBar1.Value = progress;
progressBar1.Value = progressBar1.Maximum;
Application.ShowAlertDialog("Layouts Exported Successfully");
public void ExportAllLayouts(string file)
DBDictionary layoutDICT = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
foreach (DBDictionaryEntry dictEntry in layoutDICT)
Layout layout = (Layout)tr.GetObject(dictEntry.Value, OpenMode.ForRead);
if (!layout.ModelType)
string layoutName = layout.LayoutName;
string dwgDestPathname = Regex.Replace(file, ".dwg", $"_{layoutName}.dwg");
MessageBox.Show(dwgDestPathname, "Destination Path Name", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
ExportSingleLayout(file, dwgDestPathname, layoutName);
tr.Commit();
public void ExportSingleLayout(string dwgSourcePathname, string dwgDestPathname, string layoutNameToExport = null)
db.ReadDwgFile(dwgSourcePathname, FileOpenMode.OpenForReadAndAllShare, false, null);
// Retrieve the layout dictionary
DBDictionary layoutDICT = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite);
// If no layout name is provided, set the first non-model layout as the default
if (string.IsNullOrEmpty(layoutNameToExport))
if (!layout.ModelType) // Ensure it's not the Model space
MessageBox.Show(layoutNameToExport, "Layouts Name", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
layoutNameToExport = layout.LayoutName;
break;
// If still no valid layout, throw an exception
throw new System.Exception("No valid layout found to export.");
tr.Commit();
DBDictionary layoutDict = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead) as DBDictionary;
foreach (DBDictionaryEntry de in layoutDict)
string layoutName = de.Key;
string Layouttokeep = Path.GetFileNameWithoutExtension(layoutNameToExport);
MessageBox.Show(layoutName, "Layout Name", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
if (layoutName != "Model" && layoutName != Layouttokeep)
ObjectId layoutId = (ObjectId)de.Value;
try
Layout layout = tr.GetObject(layoutId, OpenMode.ForWrite) as Layout;
LayoutManager lm = LayoutManager.Current;
if (layout != null)
lm.DeleteLayout(layoutName);
catch (Autodesk.AutoCAD.Runtime.Exception)
tr.Commit(); // Commit the transaction.
// Save the modified file to a temporary location
string tmpPathname = Path.GetTempFileName();
MessageBox.Show(tmpPathname, "Temp Save", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
db.SaveAs(tmpPathname, DwgVersion.Current);
// Ensure no file locks or issues when moving
if (File.Exists(dwgDestPathname))
try
File.Delete(dwgDestPathname);
catch (IOException ex)
throw new System.Exception($"Failed to delete the old file: {dwgDestPathname}. Error: {ex.Message}");
// Move the temporary file to the destination path
File.Move(tmpPathname, dwgDestPathname);
MessageBox.Show(dwgDestPathname, "Actual Save", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
I've seen a number of attempts at doing this, and pretty much all of them worked by copying each layout to a new DWG file, and then xreferencing the source DWG file's model space into the drawing, to avoid duplicating it in each single-layout drawing. The result was multiple single-layout DWG files, each referencing the original source DWG's model space.
I can't think of a scenario where it should be possible to edit the model space contents of the single-layout drawings.
This is basically how they work:
The above would be repeated for each Layout that is to be saved to its own DWG file.
