Error loading resources
Ed__Jobe
Mentor Mentor
Ed__Jobe
I created a test project with my new template and I get the following error when trying to netload it.
NETLOAD
Cannot load assembly. Error details: System.Resources.MissingManifestResourceException:
Could not find any resources appropriate for the specified culture or the neutral culture.
Make sure "TID_.TID_Test.resources" was correctly embedded or linked into assembly "Acad2023PluginCSharp1" at compile time, or that all the satellite assemblies required are loadable and fully signed.
Attached is the test solution. I tried some things I found on stack overflow, but they haven't worked. I even tried deleting the resources.resx file, but that didn't help either. Got any ideas?
Ed
How to post your code.
SENL1362
Caused by the line: [CommandMethod("TID", "CommandNameGlobal", "CommandNameLocalized", CommandFlags.Modal)]
Remove "CommandNameGlobal", "CommandNameLocalized" and you're problem is gone.
have a look at https://www.keanw.com/2009/06/registering-autocad-commands-with-localized-names-using-net.html
_gile
As you use a CommandMethod  attribute overload which takes a localizedNameId argument, you have to add at least one resource file to the project names MyCommands.resx. In this file you have to add an entry which key is: CommandNameLocalized.
If you want to add some localized command names, you have to add a resource file for each localized name, with the same key and a, possibly, different value (e.g. MyCommands.fr.resx with CommandNameLocalized = DIT).
The CommandMethod Attribute should be like this if tou want "TID" to be the global name.
[CommandMethod("CMDS_GROUP", "TID", "CommandNameLocalized", CommandFlags.Modal)]
Gilles Chanteau
GileCAD
GitHub
Ed__Jobe
Thanks guys. I guess I was trying to make my template too generic.
Ed
