.NET
Error From Cad, No Code generate error showing
5 REPLIES 5
351 Views, 5 Replies
Basically, my Cad extension app (button to form style) is working by appearances, but there seams to be a problem coming from the area that is recording xrecord data for my app's re use.
after my app has run and is closed, If you try to save cad gives the error message of
Error writing/closing file.
That's all it gives.
I figure perhaps I missed a transaction closure or similar, but don't see one.
So if any one has had this i could use pointers you have, or maybe some kind of transaction iterative closer to bring open transactions closed.
5 REPLIES 5
Have you found out anything about this error? The same thing happens to my apps, but If I take out the portions dealing with xrecords, no problems!
You need to send sample code in how you are doing xrecords
pat
Ok here it is:
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim Trans As Transaction = db.TransactionManager.StartTransaction
Dim LayMan As LayerStateManager = db.LayerStateManager
Try
Using Application.DocumentManager.MdiActiveDocument.LockDocument
Dim LayerT As LayerTable = Trans.GetObject(db.LayerTableId, OpenMode.ForWrite)
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim SelOps As Autodesk.AutoCAD.EditorInput.PromptSelectionOptions = New PromptSelectionOptions
Dim statename As String = ""
Dim ObjectID As Autodesk.AutoCAD.DatabaseServices.ObjectId
Dim LayersOn As ArrayList = New ArrayList
SelOps.MessageForAdding = "Select a VP"
For x As Integer = 0 To IGrid2.Rows.Count - 1
If IGrid2.Cells.Item(x, 0).Selected = True Then
statename = IGrid2.Cells.Item(x, 0).Value
Exit For
Next
If LayMan.HasLayerState(statename) Then
Dim LayerID As ObjectId = LayerT.Item("0")
db.Clayer = LayerID
LayMan.RestoreLayerState(statename, ObjectID, 2, 1023)
Dim FLayerCol As New Collection
Dim FLayerList As ArrayList = New ArrayList
For Each Lid As ObjectId In LayerT
Dim LayerX As LayerTableRecord = Trans.GetObject(Lid, OpenMode.ForRead)
If LayerX.IsFrozen = True Then
FLayerCol.Add(LayerX.Id)
Else
FLayerList.Add(LayerX.Name)
Next
Dim EntOps As PromptEntityOptions = New PromptEntityOptions("Select Viewport: ")
EntOps.AllowObjectOnLockedLayer = True
EntOps.AllowNone = False
Dim EntRes As PromptEntityResult = ed.GetEntity(EntOps)
Dim SelVP As Viewport = Nothing
If EntRes.Status = PromptStatus.OK Then
SelVP = Trans.GetObject(EntRes.ObjectId, OpenMode.ForWrite, False, True)
Else
Exit Sub
'try saving an xrecord to save which layers must be on for this layout.
Try
Dim LayoutMan As LayoutManager = LayoutManager.Current
Dim dict As DBDictionary = CType(Trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite, False), DBDictionary)
Dim rec As New Xrecord()
Dim Vals(FLayerList.Count - 1) As TypedValue
Dim TDict As DBDictionary
Try
TDict = Trans.GetObject(dict.GetAt(LayoutMan.CurrentLayout), OpenMode.ForWrite, False, True)
Catch ex As Exception
TDict = New DBDictionary
dict.UpgradeOpen()
dict.SetAt(LayoutMan.CurrentLayout, TDict)
Trans.AddNewlyCreatedDBObject(TDict, True)
End Try
Dim rb As TypedValue
Dim Entity As Autodesk.AutoCAD.DatabaseServices.Entity = Trans.GetObject(EntRes.ObjectId, OpenMode.ForWrite)
If TypeOf Entity Is Autodesk.AutoCAD.DatabaseServices.Viewport Then
Dim ThisVP As Viewport = Trans.GetObject(Entity.Id, OpenMode.ForWrite)
'Vals(0) = New TypedValue(DxfCode.Text, ThisVP.ObjectId.ToString)
FLayerList.Sort()
For x As Integer = 0 To FLayerList.Count - 1
Vals(x) = New TypedValue(DxfCode.LayerName, FLayerList.Item(x))
Next
rec.Data = New ResultBuffer(Vals)
TDict.SetAt(ThisVP.ObjectId.ToString, rec)
ThisVP.ThawAllLayersInViewport()
ThisVP.FreezeLayersInViewport(FLayerCol.GetEnumerator)
'Exit For
'Next
Dim FinaL As ArrayList = New ArrayList
Dim C As Integer = 1
Try
For Each dbEnt As DBDictionaryEntry In TDict
'ed.WriteMessage(ControlChars.Lf & "XRecord: " & dbEnt.Key & " found with the following values:" & ControlChars.Lf)
'Dim tempD As DBDictionary = Trans.GetObject(dbEnt.Value, OpenMode.ForRead)
Dim TXrec As Xrecord = CType(Trans.GetObject(TDict.GetAt(dbEnt.Key), OpenMode.ForRead), Xrecord)
If C = 1 Then
For Each rb In TXrec.Data.AsArray
FinaL.Add(rb.Value)
Next rb
C += 1
Else
If FinaL.Contains(rb.Value) = False Then
FinaL.Add(rb.Value)
Next
'For Each rb In TXrec.Data.AsArray
'ed.WriteMessage(String.Format("TypeCode={0}, Value={1}" + ControlChars.Lf, rb.TypeCode, rb.Value))
'Next rb
Next
FinaL.Sort()
For x As Integer = 0 To FinaL.Count - 1
Vals(x) = New TypedValue(DxfCode.LayerName, FinaL.Item(x))
ed.WriteMessage(ControlChars.Lf & FinaL.Item(x))
Next
TDict.SetAt("MasterList", rec)
End Try
MsgBox("The following error occurred: " & vbCrLf & ex.Message & vbCrLf & ex.StackTrace)
End Try
End Using
Trans.Commit()
Application.DocumentManager.MdiActiveDocument.LockDocument.Dispose()
TurnOnLayers(True)
ForceRegen()
'Trans.Commit()
Trans.Abort()
Finally
Trans.Dispose()
Me.Close()
End Try
cadMeUp
Make sure you are adding the new Xrecord to the transaction:
Trans.AddNewlyCreatedDBObject(rec, True)
Hope that fixes it!
Sorry for the late response. Yes it did work. Thank you very much!
”Boost
