Dynamic Block with associative hatch
SRSDS
Advisor Advisor
SRSDS
I have a problem getting the associative hatch of a dynamic block to update programatically.
They update when manually adjusting a grip stretch or modifying block dimensions using the properties palette so it's not a problem with the block.
It's a block with parameter constraints. Not sure if that's part of the problem.
I've attached an example of the type of block I have a problem with.
Is there code that might help kick hatches into position?
SRSDS
Something very odd here.
Norman Yuan posted code to test a dynamic block with an associated hatch.
https://forums.autodesk.com/t5/net/insert-dynamic-block-with-hatch/m-p/9923684
Thank you Norman. Wondered if it had something to do with locking a document.
I tested it on my home PC.
The block behaved using that code but there was still something wrong with my code.
Went to work. My code was now working which left me really confused.
Wondered if AutoDesk had pushed an update to fix the problem.
I'm now back home on my home PC and seeing the original problem.
I remotely hooked into my work PC to double check and my work PC is behaving differently to my home PC.
Same:
  • AutoCAD version
  • Visual Studio version
  • Visual Studio project (Dropbox)
Something is amiss.
SRSDS
Could it be a system variable setting?
SRSDS
Two computers at my work behave as expected, four don't. I copied the system variables between computers. Same graphics cards on computers that do and don't work. Still at a complete loss at how that could be. Makes no sense.
What I have found is that the hatches do update if a CommandMethod is used. I was using a timer in a pallete.
alexisgacia
Did you manage to fix your problem? How did you do it in timer?
SRSDS
I think so. By using SendStringToExecute a CommandMethod.
The timer is irrelevent. I use a timer to limit the number of times this is code is triggered when typing into a text box.
agabouryVN5EB
Hi so I think I found the issue it relates to the AutoCAD not being able to update the hatch graphics in time, when changes are made to the dynamic block programmatically. Every time you make a change to the dynamic block may it be transforming it, or changing a DynamicBlockReferenceProperty variable, run this snippet of code "acCurDb.TransactionManager.QueueForGraphicsFlush();" this will update the block graphics and it ensure that it displays correctly.
