- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem getting the associative hatch of a dynamic block to update programatically.
They update when manually adjusting a grip stretch or modifying block dimensions using the properties palette so it's not a problem with the block.
It's a block with parameter constraints. Not sure if that's part of the problem.
I've attached an example of the type of block I have a problem with.
Is there code that might help kick hatches into position?
