.NET
Dwg To Pdf plot
1 REPLY 1
thannaingoo.bim.mep
4494 Views, 1 Reply
Dwg To Pdf plot
Dear All,
Let me know code  reference for the dwg to pdf plot with C#.
I got error with below code.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.PlottingServices;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.Geometry;
using System.IO;
using Autodesk.AutoCAD.EditorInput;
namespace PrintPDF
    public class Class1
        [CommandMethod("eden",CommandFlags.Session)]
        public static void printpdf()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                LayoutManager layoutMgr = LayoutManager.Current;
                layoutMgr.CurrentLayout = "TSLayout";
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
                Layout lo = (Layout)tr.GetObject( btr.LayoutId, OpenMode.ForRead);
                PlotInfo pi = new PlotInfo();
                pi.Layout = btr.LayoutId;
                PlotSettings ps = new PlotSettings(lo.ModelType);
                ps.CopyFrom(lo);
                PlotSettingsValidator psv = PlotSettingsValidator.Current;
                psv.SetPlotType( ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Layout);
                psv.SetUseStandardScale(ps, true);
                psv.SetStdScaleType(ps, StdScaleType.StdScale1To1);
                psv.SetPlotCentered(ps, true);
                psv.SetPlotConfigurationName(ps,"DWG To PDF.pc3", "ISO A1(841.00 x 594.00 MM)");
                pi.OverrideSettings = ps;
                PlotInfoValidator piv =  new PlotInfoValidator();
                piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                piv.Validate(pi);
                if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                    using (PlotEngine pe = PlotFactory.CreatePublishEngine())
                        using (PlotProgressDialog ppd = new PlotProgressDialog(false, 1, true))
                            ppd.set_PlotMsgString( PlotMessageIndex.DialogTitle,
                              "Custom Plot Progress"
                              PlotMessageIndex.CancelJobButtonMessage,
                              "Cancel Job"
                              PlotMessageIndex.CancelSheetButtonMessage,
                              "Cancel Sheet"
                              PlotMessageIndex.SheetSetProgressCaption,
                              "Sheet Set Progress"
                              PlotMessageIndex.SheetProgressCaption,
                              "Sheet Progress"
                            ppd.LowerPlotProgressRange = 0;
                            ppd.UpperPlotProgressRange = 100;
                            ppd.PlotProgressPos = 0;
                            // Let's start the plot, at last
                            ppd.OnBeginPlot();
                            ppd.IsVisible = true;
                            pe.BeginPlot(ppd, null);
                            // We'll be plotting a single document
                            pe.BeginDocument(
                              pi,
                              doc.Name,
                              null,
                              1,
                              true, // Let's plot to file
                              "c:\\test-output"
                            // Which contains a single sheet
                            ppd.OnBeginSheet();
                            ppd.LowerSheetProgressRange = 0;
                            ppd.UpperSheetProgressRange = 100;
                            ppd.SheetProgressPos = 0;
                            PlotPageInfo ppi = new PlotPageInfo();
                            pe.BeginPage(
                              ppi,
                              pi,
                              true,
                              null
                            pe.BeginGenerateGraphics(null);
                            pe.EndGenerateGraphics(null);
                            // Finish the sheet
                            pe.EndPage(null);
                            ppd.SheetProgressPos = 100;
                            ppd.OnEndSheet();
                            // Finish the document
                            pe.EndDocument(null);
                            // And finish the plot
                            ppd.PlotProgressPos = 100;
                            ppd.OnEndPlot();
                            pe.EndPlot(null);
                else
                    ed.WriteMessage( "\nAnother plot is in progress.");
1 REPLY 1
One cannot Plot a Layout Area Centered, i.e. the combination of Layout and Centered is not allowed.
As an alternative u can use PlotArea Extents.
AutoCAD Inside the Factory
