Create properties in custom category
I'm new in autocad development.
I've create an arx with custom object (wrapped for C# use)
I would like to add properties (in custom category)  in property set, I saw the example asdkOPMNet but
it does not create custom category.
how can I implement this for C# ?
Thank,
Sorry for my english.
marcin.sachs
What do you mean by "Custom category"? - property set?
Please see my code below. I created custom property for polyline:
internal static void CreateSteelBeamPropertySetDefinition()
            string propertySetName = "SteelBeam";
            var database = Application.DocumentManager.MdiActiveDocument.Database;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            var PolylineClassName = RXObject.GetClass(typeof(Polyline)).Name;
            //try
            var dictionaryPropertyDataFormat = new DictionaryPropertyDataFormat(database);
            var propertySetDefinition = new PropertySetDefinition();
            using (Transaction transaction1 = database.TransactionManager.StartTransaction())
                propertySetDefinition.SetToStandard(database);
                propertySetDefinition.SubSetDatabaseDefaults(database);
                propertySetDefinition.Description = "Property Set Definition for Steel Beam";
                propertySetDefinition.AlternateName = propertySetName;
                propertySetDefinition.IsLocked = false;
                propertySetDefinition.IsVisible = true;
                propertySetDefinition.IsWriteable = true;
                var filters = new StringCollection();
                filters.Add(PolylineClassName);
                propertySetDefinition.SetAppliesToFilter(filters, false);
                //var automaticPropertyDefinition = new PropertyDefinition();
                var  propDef = new PropertyDefinition();
                propDef.SetToStandard(database);
                propDef.SubSetDatabaseDefaults(database);
                propDef.Name = "Prefix";
                propDef.Description = "Prefix of steel beam";
                propDef.IsVisible = true;
                propDef.IsReadOnly = false;
                propDef.FormatId = dictionaryPropertyDataFormat.GetAt("Standard");
                propertySetDefinition.Definitions.Add(propDef);
                propertySetDefinition.SetDisplayOrder(propDef, 1);
                propDef.Name = "Name";
                propDef.Description = "Name of steel beam";
                propertySetDefinition.SetDisplayOrder(propDef, 2);
                propDef.Name = "Style";
                propDef.Description = "Style of steel beam";
                propertySetDefinition.SetDisplayOrder(propDef, 3);
                propDef.Name = "Length2";
                propDef.Description = "Length of steel beam";
                propDef.IsVisible = false;
                propDef.IsReadOnly = true;
                propDef.SetAutomaticData(PolylineClassName, "Length");
                propertySetDefinition.SetDisplayOrder(propDef, 4);
                propDef.Name = "WeightPerMetre";
                propDef.Description = "Weight per metre";
                propertySetDefinition.SetDisplayOrder(propDef, 5);
                var dictionaryPropertySetDefinitions = new DictionaryPropertySetDefinitions(database);
                if (dictionaryPropertySetDefinitions.Has(propertySetName, transaction1))
                    return;
                dictionaryPropertySetDefinitions.AddNewRecord(propertySetName, propertySetDefinition);
                transaction1.AddNewlyCreatedDBObject(propertySetDefinition, true);
                transaction1.Commit();
            using (Transaction transaction2 = database.TransactionManager.StartTransaction())
                propertySetDefinition = transaction2.GetObject(propertySetDefinition.ObjectId, OpenMode.ForWrite) as PropertySetDefinition;
                var formulaPropertyDefinition = new PropertyDefinitionFormula();
                formulaPropertyDefinition.SetToStandard(database);
                formulaPropertyDefinition.SubSetDatabaseDefaults(database);
                formulaPropertyDefinition.Name = "Length";
                formulaPropertyDefinition.Description = "RESULT = [Length2]/1000";
                formulaPropertyDefinition.IsVisible = true;
                propertySetDefinition.Definitions.Add(formulaPropertyDefinition);
                propertySetDefinition.SetDisplayOrder(formulaPropertyDefinition, 6);
                formulaPropertyDefinition.SetFormulaString("RESULT = [Length2]/1000");
                formulaPropertyDefinition.DataItems[0].FormatId = dictionaryPropertyDataFormat.GetAt("2 Decimal");
                formulaPropertyDefinition.FormatId = dictionaryPropertyDataFormat.GetAt("2 Decimal");
                transaction2.Commit();
usage:
DictionaryPropertySetDefinitions dictPropSetDef = new DictionaryPropertySetDefinitions(db);
                if (!dictPropSetDef.Has("SteelBeam", acTrans))
                    CreateSteelBeamPropertySetDefinition();
Ta7a
what is the dlls that should be refrenced to access the PropertySetDefinition
norman.yuan
Firstly, @marcin.sachs ' reply has nothing to do with the OP's question.
PropertySetData APIs are from AecPropDataMgd.dll, which only available for AutoCAD's AEC verticals (Arch, MEP, C3D..), not for vanilla AutoCAD. The DLL is located in "C:\....\AutoCAD 202x]ACA" folder (again, if you use plain AutoCAD, there is no "....\ACA" folder).
Norman Yuan
Drive CAD With Code
ActivistInvestor
See the docs for the IAcPiCategorizeProperties class
