Dynamic Block Becomes Static After Insertion
ilovejingle
ilovejingle
I am trying to write a program to replace the old block with the new block. both blocks are dynamic. It seems the new blockreference becomes static after insertion
Is there any simpler way to insert a dynamic block which already exists in the drawing?
Here is my code :
        [CommandMethod("RP")]
        public void cmdRP()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var optEnt1 = new PromptEntityOptions("Please Select Entity to be replaced : ");
            var optEnt2 = new PromptEntityOptions("Please Select Enttity to Replace the orginal Entity : ");
            optEnt1.SetRejectMessage("Only Support Block Reference ");
            optEnt2.SetRejectMessage("Only Support Block Reference ");
            optEnt1.AddAllowedClass(typeof(BlockReference), true);
            optEnt2.AddAllowedClass(typeof(BlockReference), true);
            var blkOld = ed.GetEntity(optEnt1);
            if (blkOld.Status != PromptStatus.OK) return;
            var blkNew = ed.GetEntity(optEnt2);
            if (blkNew.Status != PromptStatus.OK) return;
            using (Transaction trans = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                try
                    var blkRefOld = trans.GetObject(blkOld.ObjectId, OpenMode.ForRead) as BlockReference;
                    var blkRefNew = trans.GetObject(blkNew.ObjectId, OpenMode.ForRead) as BlockReference;
                    var blkMat = blkRefOld.BlockTransform;
                    var newBlkRef = new BlockReference(new Point3d(0, 0, 0), blkRefNew.BlockTableRecord);
                    newBlkRef.SetDatabaseDefaults();
                    newBlkRef.TransformBy(blkMat);
                    var bt = trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead) as BlockTable;
                    var ms = trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    ms.AppendEntity(newBlkRef);
                    trans.AddNewlyCreatedDBObject(newBlkRef, true);
                    RXClass rxclass = RXObject.GetClass(typeof(AttributeDefinition));
                    var btr = trans.GetObject(blkRefOld.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
                    var collection = newBlkRef.AttributeCollection;
                    if (btr.HasAttributeDefinitions)
                        foreach (ObjectId objId in btr)
                            if (objId.ObjectClass.IsDerivedFrom(rxclass))
                                var attDef = trans.GetObject(objId, OpenMode.ForRead) as AttributeDefinition;
                                if (!attDef.Constant)
                                    var attRef = new AttributeReference();
                                    attRef.SetAttributeFromBlock(attDef,blkMat);
                                    collection.AppendAttribute(attRef);
                                    trans.AddNewlyCreatedDBObject(attRef, true);
                    bgFunction.SyncDynamicBlockProps(blkRefOld.ObjectId, newBlkRef.ObjectId, trans);
                    blkRefOld.UpgradeOpen();
                    blkRefOld.Erase();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage("Error : MAIN Method.");
                finally
                    trans.Commit();
_gile
What about this method?
Gilles Chanteau
GileCAD
GitHub
ilovejingle
This method has no relevance to this topic, it just try to copy all attributes value from the old block to the new block. I should remove it from my code before posting, sorry for that.
_gile
May be you can start from this (not deeply tested)
        public static void CmdRp()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var opts = new PromptEntityOptions("\nPlease Select Entity to be replaced : ");
            opts.SetRejectMessage("Only Support Block Reference ");
            opts.AddAllowedClass(typeof(BlockReference), true);
            var result = ed.GetEntity(opts);
            if (result.Status != PromptStatus.OK) return;
            var blkOldId = result.ObjectId;
            opts.Message = "\nPlease Select Entity to Replace the orginal Entity : ";
            var blkNewId = result.ObjectId;
            using (var tr = db.TransactionManager.StartTransaction())
                var blkRefOld = (BlockReference)tr.GetObject(blkOldId, OpenMode.ForWrite);
                var blkRefNew = (BlockReference)tr.GetObject(blkNewId, OpenMode.ForRead);
                blkRefOld.BlockTableRecord = blkRefNew.DynamicBlockTableRecord;
                foreach (ObjectId id in blkRefOld.AttributeCollection)
                    var att = (AttributeReference)tr.GetObject(id, OpenMode.ForWrite);
                    att.Erase();
                var btr = tr.GetObject(blkRefNew.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
                            var attDef = tr.GetObject(objId, OpenMode.ForRead) as AttributeDefinition;
                                attRef.SetAttributeFromBlock(attDef, blkRefOld.BlockTransform);
                                blkRefOld.AttributeCollection.AppendAttribute(attRef);
                                tr.AddNewlyCreatedDBObject(attRef, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
ilovejingle
It mazes me when it works.
What exactly happening in the code?
_gile
A BlockReference is only an inserted reference to a BlockTableRecord.
You can simply change the BlockTableRecord the BlockReference references to.
For dynamic blocks, you have to reference to the DynamicBlockTableRecord (the original definition).
Gilles Chanteau
GileCAD
GitHub
