I'm wanting to create a command that can be invoked as a Dialog or at the command line, just as there are the commands "Layer" and "-Layer" (among many others). However, when I attempt this:
[CommandMethod("-MyCommand")]
the command is not recognized by Autocad. I've read through the .NET and ObjectARX docs and have been unable to find any mention of the "-" character not being a valid character to use.
Any suggestions welcomed. (Yes, I know I can just create a similarly named command. I was hoping to mimic what Autocad does so the process will already be familiar to the end user.)
Thanks!
Solved by norman.yuan. Go to Solution.
Solved by _gile. Go to Solution.
@Jeff_M, I just recently posted something in my blog on this topic, and I have no problem to with code
[CommandMethod("-DoSothing")]
