Create a Custom Ribbon in AutoCAD 2024 using the API
eduardo_salvador02
Message 2 of 10
eduardo_salvador02
Hello!
How can I create a Custom Ribbon in AutoCAD 2024 using the API?
Replies (9)
Message 1 of 10
eduardo_salvador02
Hello!
How can I create a Custom Ribbon in AutoCAD Plant 3D 2024 using the API?
Message 3 of 10
jabowabo
Message 4 of 10
pendean
Community Legend
Community Legend
Custom Ribbon? Do you have screenshots to share, more details and specifics too?
Are you just wanting to avoid using the CUI command?
Or something else?
And which API are you talking about exactly? Or do you just have AutoCAD2024 the program?
Message 5 of 10
eduardo_salvador02
Hello!
I'm referring to the AutoCAD API, I recently developed a Plug-In for Navisworks using its API, where I created a custom tab in the menu, I believed it would be possible to do the same for AutoCAD, so I could create custom buttons that would suit my demands.
Attached is a picture of what I'm referring to.
Message 6 of 10
cadffm
There are not just one API, which one you are talking?
[F1] contain developer help doc too
Wrong board, ask in .net or .arx/C , you didn't say which API you talking about.
https://forums.autodesk.com/t5/autocad/ct-p/8
Sebastian
Message 8 of 10
eduardo_salvador02
I'm talking about of .NET API
Message 9 of 10
cadffm
okay,
follow my links,
use the search engine in .Net board
one sample hit:  https://through-the-interface.typepad.com/through_the_interface/2008/04/the-new-ribbonb.html
Sebastian
Message 10 of 10
pendean
Community Legend
Community Legend
You are in the incorrect forum, let's get your post moved to the correct one.
