How to Duplicate a Layout in a Database
Poncho_Slim
Poncho_Slim
I have attempted to Duplicate a Layout in a Database. I am unable to use a LayoutManager Object since I am trying to make changes to Documents (.dwg files) in the background to multiplle drawings in one sweep. The drawing has a layout with some viewports in it. A hard duplicate that LayoutManager.CopyLayout() worked great, but I realized that I need to be able to do this for drawings that are open in the background via accessing its Database, and since I dont have the drawing open, I wont be able to use LayoutManager.
Here is the current code I had:
private void CopyRebuildSheet()
            Debug.Print("CopyRebuildSheet");
            string newLayoutName = "";
            foreach (DataGridViewRow Row in PlanSheetsAvailableTable.Rows)
                DB_Sheet Sheet;
                Sheets.TryGetValue(Row.Cells[SheetNumColumnIndex].Value.ToString(), out Sheet);
                string FilePath = $"{Sheet.fullPath}\\{Sheet.fileName}";
                Database db = OpenDrawingFile(FilePath);
                using(Transaction tr = db.TransactionManager.StartTransaction())
                    DBDictionary layoutDic = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite) as DBDictionary;
                    foreach(DBDictionaryEntry entry in layoutDic)
                        ObjectId layoutId = entry.Value;
                        Layout layout = tr.GetObject(layoutId, OpenMode.ForRead) as Layout;
                        if (layout.LayoutName == Row.Cells[SheetNumColumnIndex].Value.ToString())
                            // Here is an ERROR
                            LayoutManager layoutManager = ;
                            //ObjectId newLayoutId = layoutManager.CreateLayout($"{layout.LayoutName} ({Row.Cells[RSNumColumnIndex].Value.ToString()})");
                            newLayoutName =$"{layout.LayoutName} ({Row.Cells[RSNumColumnIndex].Value})";
                            //Layout newLayout = tr.GetObject(newLayoutId, OpenMode.ForWrite) as Layout;
                            layoutManager.CloneLayout(layout.LayoutName, newLayoutName, layoutDic.Count);
                            if (RSSheetsToBeImportedIntoSheetSetManager.ContainsKey(Sheet.fileName))
                                RSSheetsToBeImportedIntoSheetSetManager[Sheet.fileName] += $"\n{newLayoutName}";
                            else
                                RSSheetsToBeImportedIntoSheetSetManager.Add(Sheet.fileName, newLayoutName);
                            tr.Commit();
                            break;
                EnableTheTitleBlock(newLayoutName);
norman.yuan
You need to set the side database to HostApplicationService.WorkingDatabase in order to use LayoutManager against this database. Also, you need to dispose the side database when you are done with it. Something like:
// save original working database
var originalDb=HostApplicationServices.WorkingDatabase;
foreach (.....)
  using (var db=OpenDrawingFile(...))
     HostApplicationServices.WorkingDatabase=db;
     '' identify layout to copy
     '' using LayerManager to copy a layout here
     'db.SaveAs(...);
// restore original working database
HostApplicationServices.WorkingDatabase = originalDb;
Norman Yuan
Drive CAD With Code
Poncho_Slim
This worked perfectly. Thank you for your solution. Here is the revised version:
            var originalDB = HostApplicationServices.WorkingDatabase;
                DB_Sheet Sheet;
                using(var db = OpenDrawingFile(FilePath))
                    HostApplicationServices.WorkingDatabase = db;
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                                LayoutManager layoutManager = LayoutManager.Current;
                                else
                                tr.Commit();
                                db.SaveAs(FilePath, DwgVersion.Current);
                                break;
                        HostApplicationServices.WorkingDatabase = originalDB;
norman.yuan
I think it would be slightly better, or more logically, to place
outside the "foreach..." loop: you only need to restore it back after all the files are processed. It would be even better to do it like this way:
try
    foreach (....)
finally
    // this restoration is guaranteed, even exception is raised in the processing loop
    HostApplicationServices.WorkingDatabase = origialDb;
Norman Yuan
Drive CAD With Code
