Could anyone tell me the autocad version list and its .net framework version?
swaywood
Message 1 of 23
swaywood
Hi:
   I want to know the autocad version and its .net framework version list from ACAD2007 to ACAD2017?
   And from which version the accoremgd.dll exist?
best wishes
swaywood
Accepted solutions (3)
Replies (22)
Message 21 of 23
Hey Gilles
respect to your devotion in this posts.
Just to know, is it against the Autodesk licensing and terms of use to share .net API dll so we can combine them all in one place for greater compatibility of our apps ?
Thank you in forward
Message 22 of 23
Alexander.Rivilis
It is nonsense to combine AutoCAD .NET dll's because you have to set in your's projects Copy Local to False
Otherwise, you will have many problems with the code.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 23 of 23
microtecnologo
  Thank you very much for that important table that links the autocad versions with your VS libraries, I have been using .Net for Autocad 2012 and I could not update a job to Autocad 2016, with your table I discovered that I still needed to add the reference accoremgd. Thanks again.
