integrate options into getpoint-function
jan_tappenbeck
jan_tappenbeck
Hi !
in Lisp it is possible to add options into getpoint-function by initget and the []-text. code looks like
(initget "Arc")
  (setq LAST_PT (GetPoint "\nSpecify cloud starting point or [Arc length]: "))
  (if (= LAST_PT "Arc")
    (progn
      (initget 6)
      (setq TMP (getdist (strcat "\nSpecify arc length <" (rtos ARC_DIST 2 3) ">: ")))
      (if TMP
        (Progn
          (setq ARC_DIST TMP)
          (setenv "AC_Bonus_Revcloud_Bulge" (rtos (/ ARC_DIST DIM_SCALE) 2))
      (setq LAST_PT (getpoint "\nSpecify cloud start point: "))
    ) ;;end STR "RADIUS" test
now i want to make this in vb. net - but i did not found code!
could somebody help to me?
reagards Jan
_gile
Here's a C# equivalent.
You should be able to easily convert it to VB, but if you're starting with .NET, you'd rather learn C#...
var ppo = new PromptPointOptions("\nSpecify cloud starting point or [Arc length]: ", "Arc");
var ppr = ed.GetPoint(ppo);
if (ppr.Status == PromptStatus.Keyword)
    var pdo = new PromptDistanceOptions("\nSpecify arc length: ");
    pdo.AllowNegative = false;
    pdo.AllowZero = false;
    pdo.DefaultValue = arcDist;
    var pdr = ed.GetDistance(pdo);
    if (pdr.Status == PromptStatus.OK)
        arcDist = pdr.Value;
    ppr = ed.GetPoint("\nSpecify cloud starting point: ");
    if (ppr.Status != PromptStatus.OK)
        return;
    return;
var lastPoint = ppr.Value;
Gilles Chanteau
GileCAD
GitHub
jan_tappenbeck
hi !
this was very nice and helpfull - but i have a Little additional question: how would you integrate a secound (third) Option like:
Specify cloud starting point or [Arc length,option2,option3]:
regards Jan
_gile
Just add the options in the PromptPointOptions parameters and then, you can loop while prompt result status is Keyword and check for the prompt result StringResult value.
            // set message and keywords
                "\nSpecify cloud starting point or [Arc length/Second option/Third option]: ", // message
                "Arc Second Third"); // keywords
            Point3d lastPoint;
            // loop while PromptResult.Status is Keyword
            while (true)
                // user choosed an option
                    switch (ppr.StringResult)
                        case "Arc":
                            break;
                        case "Second":
                            // do what you have to do with "Second" option here
                            break;
                        case "Third":
                            // do what you have to do with "Third" option here
                            break;
                // user specified a point
                else if (ppr.Status == PromptStatus.OK)
                    break; // exit the loop
                // user cancelled
                else
                    return;
VB conversion
            ' set message and keywords
            Dim ppo As PromptPointOptions =
                New PromptPointOptions(vbLf & "Specify cloud starting point or [Arc length/ Second option/Third option]: ", "Arc Second Third")
            Dim lastPoint As Point3d
            ' loop while PromptResult.Status is Keyword
            While True
                Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                If ppr.Status = PromptStatus.Keyword Then 'user choosed an option
                    Select Case ppr.StringResult
                        Case "Arc"
                            Dim pdo As PromptDistanceOptions = New PromptDistanceOptions(vbLf & "Specify arc length: ")
                            pdo.AllowNegative = False
                            pdo.AllowZero = False
                            Dim pdr As PromptDoubleResult = ed.GetDistance(pdo)
                            If pdr.Status = PromptStatus.OK Then
                                arcDist = pdr.Value
                            Exit Select
                        Case "Second"
                            ' do what you have to do with "Second" option here
                            Exit Select
                        Case "Third"
                            ' do what you have to do with "Third" option here
                            Exit Select
                    End Select
                ElseIf ppr.Status = PromptStatus.OK Then 'user specified a point
                    Exit While 'exit the loop
                Else 'user cancelled
                    Return
            End While
Gilles Chanteau
GileCAD
GitHub
ceethreedee.com
I keep forgetting about
While (true)
thanks @_gile
also a really good example for how to implement a simple "option" based command using c#
in for anyone is unsure what this means... it means "loop forever" so make sure you have all your exits covered!
Civil 3D 2027 / Infraworks 2027
Win 11 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the from my website below!
https://ceethreedee.com/ceethreedee-tools
