.NET
copy blockTableRecord and NamedObjectsDictionaryId from one DWT to one DWG
0 REPLIES 0
Message 1 of 1
reithinger
80 Views, 0 Replies
i want to copy alle the Block and the NamedObjectsDictionaryId from a DWT to the current DWG.
I have this code, the copy from Block are OK but not the Copy from the NamedObjectsDictionaryId. What is wrong on my code ?
Wenn you can help me. Thanks
public static void DragNDropEntitiesFromDWT(string sPath, Point3d basePoint)
         AcAp.Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
         AcDataService.Database acCurDb = doc.Database;
         Editor ed = doc.Editor;
         try
            //string strTemplatePath = @"C:\ProgramData\AKG Software\INFRASIGN8\DACH\CAD_X\RSA\DE\RegelplanBI2.dwt";
            using (doc.LockDocument())
               AcDataService.ObjectIdCollection objectIds = new AcDataService.ObjectIdCollection();
               AcDataService.ObjectIdCollection dictionaryIds = new AcDataService.ObjectIdCollection();
               var mIdMap = new AcDataService.IdMapping();
               var mDictionaryIdMap = new AcDataService.IdMapping();
               using (var trans = acCurDb.TransactionManager.StartTransaction())
                  //holt den aktuell BlockTable
                  var btCur = trans.GetObject(acCurDb.BlockTableId, AcDataService.OpenMode.ForRead) as AcDataService.BlockTable;
                  using (AcDataService.Database sourceDb = new AcDataService.Database(false, true))
                     //Load DWT File
                     sourceDb.ReadDwgFile(sPath, AcDataService.FileOpenMode.OpenForReadAndAllShare, false, null);
                     sourceDb.CloseInput(true);
                     using (var transsourcedb = sourceDb.TransactionManager.StartTransaction())
                        AcDataService.BlockTableRecord btr = (AcDataService.BlockTableRecord)transsourcedb.GetObject(AcDataService.SymbolUtilityServices.GetBlockModelSpaceId(sourceDb), AcDataService.OpenMode.ForRead);
                        foreach (AcDataService.ObjectId id in btr)
                           objectIds.Add(id);
                        var NOD = (AcDataService.DBDictionary)transsourcedb.GetObject(sourceDb.NamedObjectsDictionaryId, AcDataService.OpenMode.ForRead);
                        if (NOD.Contains(SettingsManager.dictionaryKey))
                           dictionaryIds.Add(NOD.GetAt(SettingsManager.dictionaryKey));
                        transsourcedb.Commit();
                        //Clone die Objekte in der BlockTableRecordId from aktuell DWG
                        sourceDb.WblockCloneObjects(objectIds, btCur[AcDataService.BlockTableRecord.ModelSpace], mIdMap, AcDataService.DuplicateRecordCloning.Ignore, false);
                     //Clone die Dictionary
                     sourceDb.WblockCloneObjects(dictionaryIds, acCurDb.NamedObjectsDictionaryId, mDictionaryIdMap, AcDataService.DuplicateRecordCloning.Replace, false);
                  MoveRotationScaleJig jigger = new MoveRotationScaleJig(basePoint);
                  foreach (AcDataService.ObjectId objectId in objectIds)
                     AcDataService.Entity ent = (AcDataService.Entity)trans.GetObject(mIdMap[objectId].Value, AcDataService.OpenMode.ForWrite);
                     jigger.AddEntity(ent);
                  //Start den Positionierung mit Jig
                  if (jigger.Jig(1))
                     //Passt alle Entities an
                     jigger.TransformEntities();
                     trans.Commit();
                  else
                     trans.Abort();
         catch (System.Exception ex)
            ed.WriteMessage(ex.ToString());
0 REPLIES 0
Technology Administrators
