.NET
Convert Arcs to Polylines
4 REPLIES 4
wes.newman
17852 Views, 4 Replies
I've got ObjectIds of a bunch of arcs that I need to convert to polylines for further processing.
Anyone know of a clean way to do this?
I was thinking of using the COM interface and sending the PEDIT command and converting the arcs.
The only problem is I don't know of a way to put the objectids into a selection set, then call the pedit command and use the previous selection.
Anyone know of a way to do this?
Wes
4 REPLIES 4
Jeff_M
in reply to: wes.newman
Here's something I did when I was learning, hope it helps.
        [CommandMethod("Arc2Poly")]
        public void arc2poly()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptSelectionOptions psOpts = new PromptSelectionOptions();
            psOpts.MessageForAdding = "\nSelect arcs to convert: ";
            psOpts.MessageForRemoval = "\n...Remove arcs: ";
            TypedValue[] filter = { new TypedValue(0, "ARC") };
            SelectionFilter ssfilter = new SelectionFilter(filter);
            PromptSelectionResult psRes = ed.GetSelection(psOpts, ssfilter);
            if (psRes.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (ObjectId id in psRes.Value.GetObjectIds())
                    Arc arc = (Arc)tr.GetObject(id, OpenMode.ForWrite);
                    Polyline poly = new Polyline();
                    poly.AddVertexAt(0, new Point2d(arc.StartPoint.X, arc.StartPoint.Y), GetArcBulge(arc), 0, 0);
                    poly.AddVertexAt(1, new Point2d(arc.EndPoint.X, arc.EndPoint.Y), 0, 0, 0);
                    poly.LayerId = arc.LayerId;
                    btr.AppendEntity(poly);
                    tr.AddNewlyCreatedDBObject(poly, true);
                    arc.Erase();
                tr.Commit();
        private double GetArcBulge(Arc arc)
            double deltaAng = arc.EndAngle - arc.StartAngle;
            if (deltaAng < 0)
                deltaAng += 2 * Math.PI;
            return Math.Tan(deltaAng * 0.25);
Alexander.Rivilis
in reply to: Jeff_M
And:
poly.Normal = arc.Normal;
Facebook | Twitter | LinkedIn
Expert Elite Member
wes.newman
in reply to: Jeff_M
Jeff,
Just what I was after.
Thanks!!
Wes
Thanks for the update.
Technology Administrators
