.NET
Convert 3DSolid's face to Region
4 REPLIES 4
doaiena
1715 Views, 4 Replies
I am quite new to the .NET api, so a lot of things arent clear to me and i can't find what am i doing wrong.
In short: I am traversing a 3dsolid with the BREP api, i am checking for the faces' normals and once i get to the face i am looking for, i want to "convert" it to a region. I can't seem to find a straightforward way of creating a region entity from the face's geometry.
Through a lot of reading i found out that there is quite a difference between the Geometry and DatabaseServices entities. There is not much information about creating a DBEntity from a Geometry entity.
I tried to "convert" the face's edges to DBCurves using:
Curve3d curve = edge.Curve;
Curve dbCurve = Curve.CreateFromGeCurve(curve);
The idea was to "convert" all of the face's edges to DBCurves then add all of them to a DBObjectCollection, and at the end use Region.CreateFromCurves(dbCurves). Unfortunately, this gives me a NotImplementedYet error on the CreateFromGeCurve method.
I am not sure exactly what is wrong. Either my approach is totally wrong, or my lack of knowledge of the .NET api is holding me back.
Is it possible to add DBEntities from Geometry entities, what are the best practices.. I have a lot of questions and i will be very grateful if you can guide me to some documentation and/or tutorials to read about the .NET api, because the ObjectARX documentation isn't as detailed as i would have hoped.
Thank you in advance
4 REPLIES 4
_gile
in reply to: doaiena
You can use the Solid3.CopyFace() method with the SubEntityId of the face.
        [CommandMethod("TEST")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptEntityOptions("\nSelect solid 3d: ");
            options.SetRejectMessage("\nInvalid selection.");
            options.AddAllowedClass(typeof(Solid3d), false);
            var result = ed.GetEntity(options);
            if (result.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                var solid = (Solid3d)tr.GetObject(result.ObjectId, OpenMode.ForWrite);
                var subentId = GetFaceSubentId(solid, Vector3d.XAxis);
                if (subentId != SubentityId.Null)
                    var entity = solid.CopyFace(subentId);
                    entity.ColorIndex = 1;
                    var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    curSpace.AppendEntity(entity);
                    tr.AddNewlyCreatedDBObject(entity, true);
                tr.Commit();
        static SubentityId GetFaceSubentId(Solid3d solid, Vector3d direction)
            SubentityId subEntId = SubentityId.Null;
            var entityPath = new FullSubentityPath(
                    new ObjectId[] { solid.ObjectId },
                    new SubentityId(SubentityType.Null, IntPtr.Zero));
            using (var brep = new Brep(entityPath))
                foreach (var face in brep.Faces)
                    var geomNurb = face.GetSurfaceAsNurb();
                    var weights = new DoubleCollection();
                    try { weights = geomNurb.Weights; }
                    catch { }
                    using (var dbNurb = new Autodesk.AutoCAD.DatabaseServices.NurbSurface(
                        geomNurb.DegreeInU,
                        geomNurb.DegreeInV,
                        geomNurb.IsRationalInU && geomNurb.IsRationalInV,
                        geomNurb.NumControlPointsInU,
                        geomNurb.NumControlPointsInV,
                        geomNurb.ControlPoints,
                        weights,
                        geomNurb.UKnots,
                        geomNurb.VKnots))
                        if (dbNurb.IsPlanar(out Point3d point, out Vector3d normal) &&
                            normal.IsCodirectionalTo(direction))
                            subEntId = face.SubentityPath.SubentId;
                            break;
            return subEntId;
Gilles Chanteau
GileCAD
GitHub
doaiena
in reply to: _gile
Thank you for your suggestion @_gile . Indeed the CopyFace method gets the job done.
On another note, can you recommend sources from where to learn more about the .NET api. I'm having a hard time, finding a more in depth learning resource.
_gile
The ObjectARX: Managed .NET Reference Guide on this page is a quite good starting resource. you can also find some more undocumented APIs using Visual Studio Object Explorer or a .NET decompiler like IlSpy.
Gilles Chanteau
GileCAD
GitHub
joaquin.cajalv
in reply to: _gile
Hello @_gile how use this lines of coding? block de notes and save extension .DLL ?
AutoCAD Inside the Factory
