connecting between two objects
solom.gamal19991
solom.gamal19991
hi
i want to connect two object as shown in image
the connection should be vertical & horizontal with filet corners.
hosneyalaa
Hi
Create new point from (p1.x , p2.y)
Put bugle in vertex 2
And use this
https://forums.autodesk.com/t5/net/drawing-a-polyline-using-prompted-user-integers-with-autocad-net/...
solom.gamal19991
Can you post example  code😊
_gile
Could you post a drawing sample so that we can understand your request: what kind of objects you want to connect, what is the fillet radius.
And also what code you have written so far to achieve this.
Gilles Chanteau
GileCAD
GitHub
solom.gamal19991
for fillet I want to draw polyline with automatic  rounded corners
@_gile @
hosneyalaa
Hi
Please as @_gile said
Attached example drawing for better
