.NET
Common function for a namespace
6 REPLIES 6
parikhnidi
585 Views, 6 Replies
Is there a way to define a private function that is accessible to all classes within that namespace? I have developed many classes within the namespace and each class (object) has a Draw() method to draw that object.
What I noticed that, within the Draw() method I will need to call a common function with the following signature. It returns void.
CreateObject(Point2dCollection pPoints, Vector3d pDirection, Vector3d pDisplacement)
This would help me in debugging the code at one place only.
Nimish
6 REPLIES 6
_gile
in reply to: parikhnidi
A method have to be declared in a class, a structure or an interface.
You should show more code, so that's easier to understand your issue.
According to your description, the OOP way should be that all your classes derive from an abstract class in which the CreateOject is defined.
Another way to make a method easily accessible for all classes of a namespace is to make a static method in an Helpers class.
Gilles Chanteau
GileCAD
GitHub
parikhnidi
in reply to: _gile
Sorry for getting back late. I will get you the code I am using over the weekend.
Nimish
parikhnidi
in reply to: _gile
Hi @_gile
Here is the code for one of the class within the namespace. As you can see from the code below -
I am executing following steps that are common to most of the classes.
  1.  Create a Polyline.
  2. Add vertices to this Polyline from Point2dCollection parameter.
  3. Add newly created Polyline to DBObjectCollection variable.
  4. Create region.
  5. Revolve region object about Y-axis 360°.
  6. Align solid achieved by revolution above to suit desired Direction parameter.
  7. Move object using Displacement parameter.
I am trying to conceive a function something like a following signature -
RevolveAndAlineObject(Point2dCollection Polypoints, Vector3d Direction, Vector Displacement)
I've written plenty of drafting helper functions in an independent class called DrawingHelper. But, I was thinking to use proposed function within the namespace specified.
Is there a way to create function that will be exclusively used by the classes within the namespace.
Nimish
public class Shell3d
    private double _InsideDiameter, _Thickness, _Length;
    private Point3d _Location;
    private Vector3d _Direction;
    private readonly Point2dCollection ShellPoints = new Point2dCollection();
    private Point3d Origin3d = new Point3d(0, 0, 0);
    private Point2d Origin2d = new Point2d();
    private Vector3d DisplacementVector;
    public double InsideDiameter
        set { _InsideDiameter = value; }
        get { return _InsideDiameter; }
    public double Thickness
        set { _Thickness = value; }
        get { return _Thickness; }
    public double Length
        set { _Length = value; }
        get { return _Length; }
    public Point3d Location
        set { _Location = value; }
        get { return _Location; }
    public Vector3d Direction
        set { _Direction = value; }
        get { return _Direction; }
    private void CalculateProperties()
        Origin2d = Origin3d.Convert2d(new Plane(Origin3d, Vector3d.ZAxis));
        DisplacementVector = Origin3d.GetVectorTo(_Location);
    private void CalculateVertices()
        Point2d tempPoint2d;
        CalculateProperties();
        ShellPoints.Clear();
        tempPoint2d = Origin2d.Add(new Vector2d(_InsideDiameter / 2, _Length / 2));
        ShellPoints.Add(tempPoint2d);
        tempPoint2d = tempPoint2d.Add(new Vector2d(_Thickness, 0));
        tempPoint2d = tempPoint2d.Add(new Vector2d(0, -_Length));
        tempPoint2d = tempPoint2d.Add(new Vector2d(-Thickness, 0));
    public void Draw()
        Document acaddoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
        Database acaddb = acaddoc.Database;
        //Editor edt = acaddoc.Editor;
        CalculateVertices();
        int VertexIndex = 0;
        Polyline ShellPolyLine = new Polyline();
        foreach (Point2d ShellPoint in ShellPoints)
            ShellPolyLine.AddVertexAt(VertexIndex, ShellPoint, 0, 0, 0);
            VertexIndex += 1;
        ShellPolyLine.Closed = true;
        DBObjectCollection pl = new DBObjectCollection();
        pl.Add(ShellPolyLine);
        DBObjectCollection regn = Region.CreateFromCurves(pl);
        Region region = (Region)regn[0];
        Solid3d Shell = new Solid3d();
        Shell.Revolve(region, Origin3d, new Vector3d(0, 1, 0), 2 * PI);
        if (_Direction.X == 0 && _Direction.Y == 0)
            Shell.TransformBy(Matrix3d.Rotation(PI / 2, (_Direction.Z > 0 ? 1 : -1) * Vector3d.XAxis, Origin3d));
        else
            Vector3d XYVector = _Direction.OrthoProjectTo(Vector3d.ZAxis);
            double rotation = Vector3d.YAxis.GetAngleTo(XYVector, Vector3d.ZAxis);
            Shell.TransformBy(Matrix3d.Rotation(rotation, Vector3d.ZAxis, Origin3d));
            Vector3d RotAxis = XYVector.GetPerpendicularVector().Negate();
            rotation = XYVector.GetAngleTo(_Direction, RotAxis);
            Shell.TransformBy(Matrix3d.Rotation(rotation, RotAxis, Origin3d));
        Shell.TransformBy(Matrix3d.Displacement(DisplacementVector));
        using (Transaction trans = acaddb.TransactionManager.StartTransaction())
            BlockTable bt;
            bt = trans.GetObject(acaddb.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord btr;
            btr = trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
            btr.AppendEntity(Shell);
            trans.AddNewlyCreatedDBObject(Shell, true);
            trans.Commit();
}//Class - Shell3d
_gile
I'm not able to fully understand what you want to achieve but if your different classes have common methods and properties, you should use inheritance.
You create an abstract base class which contains the common methods and properties and the abstract members required by the common methods. Then make each class deriving from the base class.
See this topic:
https://docs.microsoft.com/en-us/dotnet/csharp/fundamentals/object-oriented/inheritance
Gilles Chanteau
GileCAD
GitHub
parikhnidi
in reply to: _gile
Thanks a lot @_gile
It works great. I was able to compact the code substantially. Here is the finished product.
Nimish
Base class:
    public abstract class RevolvedObject
        protected double _InsideDiameter, _Thickness;
        protected Point3d _Location;
        protected Vector3d _Direction;
        protected Point2dCollection _ProfilePoints = new Point2dCollection();
        protected Point3d Origin3d = new Point3d(0, 0, 0);
        protected Point2d Origin2d = new Point2d(0, 0);
        public void Draw()
            Polyline ProfilePolyLine = new Polyline();
            foreach (Point2d _ProfilePoint in _ProfilePoints)
                ProfilePolyLine.AddVertexAt(VertexIndex, _ProfilePoint, 0, 0, 0);
                VertexIndex += 1;
            ProfilePolyLine.Closed = true;
            pl.Add(ProfilePolyLine);
            Solid3d RevolvedObject = new Solid3d();
            RevolvedObject.Revolve(region, Origin3d, new Vector3d(0, 1, 0), 2 * PI);
                RevolvedObject.TransformBy(Matrix3d.Rotation(PI / 2, ((_Direction.Z > 0) ? 1 : -1) * Vector3d.XAxis, Origin3d));
            else
                RevolvedObject.TransformBy(Matrix3d.Rotation(rotation, Vector3d.ZAxis, Origin3d));
                RevolvedObject.TransformBy(Matrix3d.Rotation(rotation, RotAxis, Origin3d));
            RevolvedObject.TransformBy(Matrix3d.Displacement(DisplacementVector));
                BlockTable bt;
                btr.AppendEntity(RevolvedObject);
                trans.AddNewlyCreatedDBObject(RevolvedObject, true);
                trans.Commit();
Inherited class
public class Shell3d : RevolvedObject
        private double _Length;
            Point2d tempPoint;
            _ProfilePoints.Clear();
            tempPoint = Origin2d.Add(new Vector2d(_InsideDiameter / 2, _Length / 2));
            _ProfilePoints.Add(tempPoint);
            tempPoint = tempPoint.Add(new Vector2d(_Thickness, 0));
            tempPoint = tempPoint.Add(new Vector2d(0, -_Length));
            tempPoint = tempPoint.Add(new Vector2d(-Thickness, 0));
        public new void Draw()
            base.Draw();
_gile
You should not have to redefine tke Draw method in the derived classes.
In the RevolvedObject class, you can declare the CalculateVertices method as abstract:
protected abstract void CalculateVertices();
and call this method in the Draw method to fill the _Profilepoints field*.
In each derived classes you'll have to define an overriden CalculateVertices method.
protected override void CalculteVertices()
    // here the code for each specific class
* by my side, I won't use methods which return void and fill a field by  a side effect. I'd rather use methods with explicit return values (e.g. a Point3dCollection for CalculateVetices).
Gilles Chanteau
GileCAD
GitHub
Technology Administrators
