.NET
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Command("Erase".. not behaving when run through ExecuteInCommandContextAsync
1 REPLY 1
h3nrik
377 Views, 1 Reply
Hi
I have faced an issue I do not understand,
edit 4 of the post, added more tests ๐Ÿ™‚
edit 5, simplified first method even more.
This method,
[CommandMethod("testListConvertDxfDwgwithoutList", CommandFlags.Session)]
        public static async void testListConvertDxfDwgwithoutList()
            try
                var promptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetString("\nEnter the parameter: ");
                if (promptResult.Status != PromptStatus.OK)
                    return;
                var path = promptResult.StringResult;
                DocumentCollection acDocMgr = Application.DocumentManager;
                var doc = acDocMgr.Open(path, false);
                Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
                await Application.DocumentManager.ExecuteInCommandContextAsync(
                    async (obj) => {
                        await ed.CommandAsync(new object[] { "testConvertDxfDwg" });
                    null);
            } catch (Autodesk.AutoCAD.Runtime.Exception e)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(e.ToString());
testConvertDxfDwg
    public class testDxfDwg {
        [CommandMethod("testConvertDxfDwg")]
        public void testConvertDxDwg()
            var doc = Application.DocumentManager.MdiActiveDocument;
            doc.Editor.Command("ERASE", "CROSS", "0,0", "500,500", "");
If I run test testListConvertDxfDwgwithoutList from a .scr file, like this:
secureload 0
netload "...."
testListConvertDxfDwg "path to dxf.file"
Only two object, that are in 0,0 will be erased. Nothing else.
If I open the dxf manually,  run this .scr file
secureload 0
netload "..."
testConvertDxfDwg
Erase will work and all 300ish object in the 0,0 - 500,500 area will be erased
Edit 4.
I changed the Erase command call to this,
doc.Editor.Command("_.ERASE", "CROSS", "-10,-10", "-5,-5", "");
When running it through the testListConvert... call, it still selects and erases the two objects that are in 0,0 but if I run it manually, it erases nothing (the expected behavior) How ?
So what am I missing? ๐Ÿ™‚
1 REPLY 1
h3nrik
in reply to: h3nrik
I was missing the fact that I was required to execute a zoom extend before the erase call.
AutoCAD Inside the Factory
