Check is font file missing
tom.zhengGNS4G
tom.zhengGNS4G
Hi! I'm trying to find a way to check if any font file is missing. In AutoCAD, there's a little yellow icon displayed if this font file is missing:
I wrote a command to test, I can access FileName and BigFontFileName property of TextStyleTableRecord:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application;
[CommandMethod("TT")]
public void TT()
    try
        Document doc = AcadApplication.DocumentManager.MdiActiveDocument;
        Database database = doc.Database;
        Editor editor = doc.Editor;
        using (var tr = database.TransactionManager.StartTransaction())
            var textStyleTbl = database.TextStyleTableId.GetObject(OpenMode.ForRead) as TextStyleTable;
            foreach (ObjectId objId in textStyleTbl)
                var textStyle = objId.GetObject(OpenMode.ForRead) as TextStyleTableRecord;
                editor.WriteMessage($"\nfont file:{textStyle.FileName}, " +
                    $"big font file:{textStyle.BigFontFileName}");
                //...isFontMissing(textStyle.FileName);
    catch (System.Exception ex)
        AcadApplication.ShowAlertDialog("Unhandled Exception:\n" + ex.Message);
        return;
 Is it possible to do this via .NET api ? Any suggestion is really appreciated!
Replies (10)
SENL1362
Try these locations:
A. For (Big) font files named "*.ttf" look in the folder: System.Environment.SpecialFolder.Fonts
if not found then: missing...
B. For (Big) font files named "*.dbx" look in:
1. Acad.exe folder(Commandline arg[0])
2. Acad Search Path's("ACADPREFIX")
C. For any other fontfile extension (*.shx, or no extension,...)
1. Search A
2. Search B
D. Don't forget to look in the Font MAP file C:\Program files\... *.fmp,  %appdata%\...
It maps fontnames to TTF files.
tom.zhengGNS4G
Thanks for your suggestion. I would give it a try!
But I'm not sure how to get Acad.exe folder with code. (not sure what Commandline arg[0] means). Can you explain that part for me? Thank you
SENL1362
var acadCmdline = Environment.CommandLine;
//Or
var acadArgs = Environment.GetCommandLineArgs();
tom.zhengGNS4G
Thanks for your help! I have try your suggestion and it seemed to work good. But I met some issue :
(1) some of dwg files I have tested has text style SIMPLEX and ITALIC, their FileName is also SIMPLEX and ITALIC(with no extension). I can't find them in every directories but in AutoCAD, they are not shown missing. should I skip them? or are they store in Font Map file as you mentioned before? but I'm not sure where would *.fmp file located. (I didn't see any of it in C:/ProgramFiles/... and %appdata%/... )
(2) I have tested one file that has a text style named C2. in AutoCAD its font file is txt.shx, but its FileName return txt(with no extension). that made the result being missing (but actually exists in one of search paths). but only one dwg file has this strange issue. I have checked some other dwg files which also contains txt.shx font, but in other files FileName property always return txt.shx
below is my code snippet for checking if font file missing based on logic you seggested :
bool checkIsFontFileMissing(TextStyleTableRecord textStyle)
    bool isFontMissing = true;
    bool isBigFontMissing = true;
    string fileName = textStyle.FileName;
    string bigFontFileName = textStyle.BigFontFileName;
    if (fileName == "") isFontMissing = false;
    if (bigFontFileName == "") isBigFontMissing = false;
    bool checkFontFileExist(string file)
        bool findSystemFontFolder()
            string folderPath = Environment.GetFolderPath(Environment.SpecialFolder.Fonts);
            string filePath = System.IO.Path.Combine(folderPath, file);
            return System.IO.File.Exists(filePath);
        bool findAcadFolder()
            string acadPath = Environment.GetCommandLineArgs()[0];
            string acadFolder = System.IO.Path.GetDirectoryName(acadPath);
            string filePath = System.IO.Path.Combine(acadPath, file);
        bool findSearchPath()
            object acadObject = AcadApplication.AcadApplication;
            object preferences = acadObject.GetType().InvokeMember("Preferences", System.Reflection.BindingFlags.GetProperty, null, acadObject, null);
            object files = preferences.GetType().InvokeMember("Files", System.Reflection.BindingFlags.GetProperty, null, preferences, null);
            string searchPathStr = (string)files.GetType().InvokeMember("SupportPath", System.Reflection.BindingFlags.GetProperty, null, files, null);
            string[] searchPaths = searchPathStr.Split(';');
            foreach (string folderPath in searchPaths)
                if (System.IO.File.Exists(filePath)) return true;
            return false;
        string extension = System.IO.Path.GetExtension(file);
        if (extension == ".ttf")
            return findSystemFontFolder();
        else if (extension == ".dbx")
            return findAcadFolder() || findSearchPath();
        else
            return findSystemFontFolder() || findAcadFolder() || findSearchPath();
    isFontMissing = !checkFontFileExist(fileName);
    isBigFontMissing = !checkFontFileExist(bigFontFileName);
    return isFontMissing || isBigFontMissing;
apologize for the long code. do you have idea about the issues? thanks for your time and help!
SENL1362
Acad.fmp:
C:\Program Files\Autodesk\AutoCAD 20xx\UserDataCache\Support
DwgViewr.fmp:
C:\Program Files\Autodesk\DWG TrueView 2022 - English\UserDataCache\Support
tom.zhengGNS4G
Have checked the path you provide, I found a file C:\Program Files\Autodesk\AutoCAD 20xx\UserDataCache\Support\acad.fmp. but not found SIMPLEX and ITALIC in it. I'm wondering if these two are something like built-in font? so they don't have a referenced file.
SENL1362
%appdata%\Autodesk\...\Support\Simplex.shx
C:\Program Files\Autodesk\AutoCAD xxx\Fonts\italic.shx
There are a few ways to check Drawing dependencies, for Fonts, the easiest way may be:
1. Create or Open your drawing;
2. Add some Text in your Font;
3. Create Transmittal (Click AutoCAD Logo/Send/eTransmit)
4. View Report
tom.zhengGNS4G
Very informative and helpful! after I test some more files, there're still some strange situations, such as FileName doesn't contain extension(but actually there's file in support search path). but most of them working as expected(same as the result shown in AutoCAD). I'll keep trying when I have time. Thanks for your time and help!
_gile
What about using the HostApplicationServices.FindFile method?
Here's an extension method:
public static bool TryFindFile(this Database db, string fileName, FindFileHint hint, out string path)
    try
        path = HostApplicationServices.Current.FindFile(fileName, db, hint);
        return true;
    catch
        path = null;
        return false;
Using example:
var db = HostApplicationServices.WorkingDatabase;
if (db.TryFindFile("china.shx", FindFileHint.FontFile, out string path))
Gilles Chanteau
GileCAD
GitHub
tom.zhengGNS4G
Hi @_gile ! Thanks for your information. I tried your suggestion and implement the function using HostApplicationServices api like below:
(the Active.Database is a helper class in my project which provides an easy way to access Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database)
bool checkIsFontMissingByHostApplication(string fileName)
    bool tryFindFile(FindFileHint hint)
        try
            HostApplicationServices.Current.FindFile(fileName, Active.Database, hint);
            return true;
        catch
            return false;
    return !tryFindFile(FindFileHint.Default) &&
        !tryFindFile(FindFileHint.FontFile) &&
        !tryFindFile(FindFileHint.TrueTypeFontFile) &&
        !tryFindFile(FindFileHint.FontMapFile);
this api makes my code much more cleaner and run as expected. but there're 2 files arial.ttf/stylu.ttf can't be found by this approach. these 2 files is located in C:\Windows\Fonts
So for now, my workaround is to merge my original approach and HostApplicationServices api together. I have tested some dwg files and this approach works as expected(at least in all my testing file). This approach may be messy and not a good one, but at least it can be a temporary solution. It looks like :
            return false;
        bool findByHostApplicationApi()
                try
                    HostApplicationServices.Current.FindFile(file, Active.Database, hint);
                    return true;
                catch
                    return false;
            return tryFindFile(FindFileHint.FontFile) ||
                tryFindFile(FindFileHint.TrueTypeFontFile) ||
                tryFindFile(FindFileHint.FontMapFile) ||
                tryFindFile(FindFileHint.Default);
            return findSystemFontFolder() || findByHostApplicationApi();
            return findAcadFolder() || findSearchPath() || findByHostApplicationApi();
        else
            return findSystemFontFolder() || findAcadFolder() || findSearchPath() || findByHostApplicationApi();
 Thanks for all the information you provided! It really helps a lot. I'll update if I find a better approach to do this.
