I know this has been asked but its never been fully answered form what I can find.
Answer I have found:
Document newDWG = DocumentManager.open(FilePath);
newDWG.IsReadOnly will return if the previous open resulted in a readonly file. That is fine but it forces you to fully open the drawing only to find out its open on the network someplace else.
The solution I need is closer to the how CAD itself performs this. Checking for read only and returning the Username and PC name of who has it open. I cannot find a solution to produce a similar result. Even if I have to load the full document is there a way to return the current user and or PC name?
thanks
Solved by SENL1362. Go to Solution.
I would first check for the file readonly attribute and then look for the Autodesk Lock File, as shown below.
To be on the save site use a proper XML parsing for decoding the DWL2 contents.
[CommandMethod("TestDwgInUse")] public void TestDwgInUse() { Document doc = AcadApp.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; string pathname = @"C:\Temp"; string dwgName = "TestDrawing"; try { string dwgPathname = Path.Combine(pathname, dwgName + ".dwg"); string dwlPathname = Path.Combine(pathname, dwgName + ".dwl"); string dwl2Pathname = Path.Combine(pathname, dwgName + ".dwl2"); //XML formatted if (!File.Exists(dwgPathname)) throw new System.Exception(string.Format("File not found: {0}", dwgPathname)); var fileAttributes = File.GetAttributes(dwgPathname); if (fileAttributes == FileAttributes.ReadOnly) throw new System.Exception(string.Format("File ReadOnly: {0}", dwgPathname)); if (File.Exists(dwl2Pathname)) { ed.WriteMessage("\n {0}", Path.GetFileName(dwgPathname)); //Becareful: the file will be in use, so File.ReadXXX will not work using (FileStream stream = File.Open(dwl2Pathname, FileMode.Open, FileAccess.Read, FileShare.ReadWrite)) { //Use a XML parser or do it the simple way using (StreamReader reader = new StreamReader(stream)) { while (!reader.EndOfStream) { //<?xml version="1.0" encoding="UTF-8"> //<whprops> //<username>TheUserName</username> //<machinename>ThePCName </machinename> //<fullname></fullname> //<datetime>TheDate</datetime> //</whprops> var dwl2Line = reader.ReadLine(); var tmpDwl2Line = dwl2Line.Split(new char[] { '<', '>' }); if (tmpDwl2Line.Length > 4) { switch (tmpDwl2Line[1].ToUpper()) { case "USERNAME": ed.WriteMessage("\n\t Locked By: {0}", tmpDwl2Line[2]); break; case "MACHINENAME": ed.WriteMessage("\n\t Locked On: {0}", tmpDwl2Line[2]); break; case "DATETIME": ed.WriteMessage("\n\t Locked At: {0}", tmpDwl2Line[2]); break; } } } } } } } catch (System.Exception ex) { ed.WriteMessage(ex.Message); } }
o Man, not sure why I didnt think to check the lock file.
I'm going to blame it on yesterday being my last day before holidays.
thank you so much.
