.NET
Change the Underlying Drawing File of Sheet Set Sheet
9 REPLIES 9
Message 1 of 10
ChrisPicklesimer
2344 Views, 9 Replies
I have created a few sheets sets (dst files) and placed them in separate folders along with their accompanying dwg files. Currently, folder and file names are specific to each sheet set. For instance, I have a sheet set named abc.dst that resides in folder ...\acb\. In that folder I have the following drawing files: abc-1.dwg, acb-2.dwg and abc-3.dwg. These files contain the layouts that make up the sheets in the sheet set.
I now want to copy the sheet set dst file along with the associated dwg files into a new directory ...\xyz . I am able to do this and even rename the sheet set file to xyz.dst while keeping the copied dwg files connected the renamed sheet set. My problem is the drawing file names . I want to rename the xyz-1.dwg, xyz-2.dwg and xyz-3.dwg files and keep them connected without having to re-import into my sheet set. The sheets have been numbered and ordered in a such a way that it would create a great deal of effort if I had to go the re-import route.
Is there a way to change the underlying drawing file of any sheet in the sheet set?
Chris
9 REPLIES 9
Message 2 of 10
khoa.ho
in reply to: ChrisPicklesimer
SheetSet Manager API is COM API which requires to reference AcSmComponents Type Library. Depend on AutoCAD version, you should reference the appropriate AcSmComponentsXX 1.0 Type Library, with XX is 18 or 19 or 20. SheetSet COM API looks strange comparing to normal AutoCAD .NET API.
The following code was tested to work on AutoCAD 2014, to change all drawing names containing "ABC" to "XYZ" on a given DST binary file.
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
// SheetSet COM Reference:
// *18 for AutoCAD 2010, 2011, 2012
// *19 for AutoCAD 2013, 2014
// *20 for AutoCAD 2015
using ACSMCOMPONENTS19Lib;
[assembly: CommandClass(typeof(NetScript.Acad.Command))]
namespace NetScript.Acad
    public partial class Command
        [CommandMethod("ChangeSheetSetSheet")]
        public static void ChangeSheetSetSheet()
            string filePath = @"C:\Temp\SampleSheetSet.dst";
            string oldName = "ABC";
            string newName = "XYZ";
            try
                // Get the SheetSet Manager
                AcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
                // Create a new SheetSet Database
                AcSmDatabase sheetSetDb = new AcSmDatabase();
                // Open DST file
                sheetSetDb = sheetSetManager.OpenDatabase(filePath, true);
                // Lock the db for processing
                sheetSetDb.LockDb(sheetSetDb);
                AcSmSheetSet sheetSet = sheetSetDb.GetSheetSet();
                // Recursive method to change name
                ProcessEnumerator(sheetSet.GetSheetEnumerator(), oldName, newName);
                // Unlock the db after processing
                sheetSetDb.UnlockDb(sheetSetDb, true);
                sheetSetManager.Close(sheetSetDb);
            catch (System.Exception ex)
        private static void ProcessEnumerator(IAcSmEnumComponent component, string oldName, string newName)
            IAcSmComponent item = component.Next();
            while (item != null)
                string type = item.GetTypeName();
                switch (type)
                    case "AcSmSheet":
                        try
                            AcSmSheet sheet = (AcSmSheet)item;
                            AcSmAcDbLayoutReference layout = sheet.GetLayout();
                            string sheetName = sheet.GetName();
                            string fileName = layout.GetFileName();
                            string newSheetName = sheetName.Replace(oldName, newName);
                            string newFileName = fileName.Replace(oldName, newName);
                            // Update sheet name and file name
                            sheet.SetTitle(newSheetName);
                            layout.SetFileName(newFileName);
                            if (!string.IsNullOrEmpty(sheetName))
                                IAcSmEnumComponent enumerator = (IAcSmEnumComponent)sheet.GetSheetViews();
                                ProcessEnumerator(enumerator, oldName, newName);
                        catch { }
                        break;
Credit to Kean's blog: http://through-the-interface.typepad.com/through_the_interface/2010/05/populating-a-tree-view-inside...
And Fenton's blog: http://adndevblog.typepad.com/autocad/2013/09/using-sheetset-manager-api-in-vbnet.html
Message 3 of 10
ChrisPicklesimer
in reply to: khoa.ho
Thanks!  That is exactly what I was looking for.
Chris
Message 4 of 10
khoa.ho
Can you mark it as accepted solution please? Thanks. You can extend the code to change physical drawing file names together with drawing names in the sheet set.
Message 5 of 10
ChrisPicklesimer
Done.  I am curious now about how to change the file names.  I am doing it now in another part of the code with
IO.File.Copy but would like to see the method of which you speak.
Chris
Message 6 of 10
khoa.ho
Great! I knew the change file name code should be included for the complete solution. I am going to the meeting now and will be back in couple of hours.
Khoa
Message 7 of 10
khoa.ho
Here is the completed code. I made it more generic to further custom extensions. Please see Kean's post to add more code when needed.
I use a struct to pass an encapsulate object to the recursive method when navigating the sheet set. Use System.IO.File.Copy to copy files and System.IO.File.Move to rename files. The code can do direct renaming files or copy files to another location. See the comments for information.
// Credit to Kean Walmsley blog: http://through-the-interface.typepad.com/through_the_interface/2010/05/populating-a-tree-view-inside...
// Credit to Fenton Webb blog: http://adndevblog.typepad.com/autocad/2013/09/using-sheetset-manager-api-in-vbnet.html
// Written by Khoa Ho - www.NetOnApp.com
using System;
using System.IO;
using System.Windows.Forms;
[assembly: CommandClass(typeof(NetScript.Acad.CodeLibrary.App.Command))]
namespace NetScript.Acad.CodeLibrary.App
            string sheetSetPath = @"C:\Temp\Old\NewSheetSet.dst";
            string oldFileName = "ABC";
            string newFileName = "XYZ";
            string oldFolderName = @"C:\Temp\Old"; // Leave empty for current saved location
            string newFolderName = @"C:\Temp\New"; // Leave empty for rename files
            try
                // Open DST file
                sheetSetDb = sheetSetManager.OpenDatabase(sheetSetPath, true);
                // Create a wrapper of all needed properties
                var componentInfo = new ComponentInfo
                    TreeNode = new TreeNode(sheetSet.GetName()),
                    OldFileName = oldFileName,
                    NewFileName = newFileName,
                    OldFolderName = oldFolderName,
                    NewFolderName = newFolderName
                // Recursive method to navigate sheet set
                ProcessEnumerator(sheetSet.GetSheetEnumerator(), componentInfo);
                // Unlock the db after processing, save it to the current file
        private static void ProcessEnumerator(IAcSmEnumComponent component, ComponentInfo componentInfo)
                switch (type)
                    case "AcSmSheet":
                        try
                            RenameSheets(sheet, componentInfo);
                                ProcessEnumerator(enumerator, componentInfo);
                        catch { }
                        break;
                    case "AcSmSubset":
                        break;
                    case "AcSmSheetViews":
                        break;
                    case "AcSmSheetView":
                        break;
                    case "AcSmCustomPropertyValue":
                        break;
                    case "AcSmObjectReference":
                        break;
                    case "AcSmCustomPropertyBag":
                        break;
                    case "AcSmAcDbLayoutReference":
                        break;
                    case "AcSmFileReference":
                        break;
                    case "AcSmAcDbViewReference":
                        break;
                    case "AcSmResources":
                        break;
                    default:
                        break;
        private static void RenameSheets(AcSmSheet sheet, ComponentInfo componentInfo)
            // Skip this method if there is no need to rename sheets
            if (string.IsNullOrEmpty(componentInfo.OldFileName) &&
                string.IsNullOrEmpty(componentInfo.NewFileName))
                return;
            try
                string filePath = layout.GetFileName();
                string fileFolder = Directory.GetParent(filePath).FullName;
                string fileName = Path.GetFileName(filePath);
                    componentInfo.OldFileName, componentInfo.NewFileName);
                //* Update sheet names and file names on DST file
                // Rename DWG files in the existing folder or copy them to the new folder
                if (!string.IsNullOrEmpty(componentInfo.OldFolderName) &&
                    !string.IsNullOrEmpty(componentInfo.NewFolderName))
                    // Copy files from the old to new location
                    string oldFilePath = Path.Combine(componentInfo.OldFolderName, fileName);
                    string newFilePath = Path.Combine(componentInfo.NewFolderName, newFileName);
                    if (File.Exists(oldFilePath))
                        File.Copy(oldFilePath, newFilePath); // Copy physical file
                        // Update sheet set
                        layout.SetFileName(newFilePath);
                else if (string.IsNullOrEmpty(componentInfo.OldFolderName) &&
                    // Copy files from the current to new location
                    string currentFilePath = Path.Combine(fileFolder, fileName);
                    if (File.Exists(currentFilePath))
                        File.Copy(currentFilePath, newFilePath); // Copy physical file
                        // Update sheet set
                else if (string.IsNullOrEmpty(componentInfo.NewFolderName))
                    // Rename files in the current location
                    string newFilePath = Path.Combine(fileFolder, newFileName);
                        File.Move(currentFilePath, newFilePath);
                        // Update sheet set
    internal struct ComponentInfo
        public TreeNode TreeNode;
        public string OldFileName;
        public string NewFileName;
        public string OldFolderName;
        public string NewFolderName;
Message 8 of 10
ChrisPicklesimer
Thanks again!  This has really helped.
Chris
Message 9 of 10
This is exactly what I need to do, how do I apply this coding to autocad 2018?
Message 10 of 10
ActivistInvestor
You have to compile the code into a .DLL using Visual Studio and then use the NETLOAD command to load and run it.
”Boost
