I created a plate and later removed the hole to form an arc in the plate(attached image). However the boolean operation(boolsubstract) or the regions created is generating an arc with white colour, where as my remaining profile is red ( in program referred as colorindex CONTOUR = 0). I would like to change the arc color to red to make the profile look uniform. can someone please help me.
Thank you very much
My coding for creating region of the arc and boolean operation
// create solid of the arc
curves.Clear();
Circle arc = new Circle();
arc.Center = new Point3d(plate.L1 / 2.0, plate.L6, -plate.t);
arc.Diameter = plate.L2;
arc.ColorIndex = plate.nColor[CONTOUR];
curves.Add(arc);
// create the region from the curves
regions = Region.CreateFromCurves(curves);
holeSolid.Extrude((Region)regions[0], 3.0 * plate.t, 0);
holeSolid.ColorIndex = plate.nColor[CONTOUR];
// substract the hole solid from the rectangle
plateSolid.BooleanOperation(BooleanOperationType.BoolSubtract, holeSolid);
Solved by moogalm. Go to Solution.
Can you please share the full reproducible code sample, I can have test it at my end..
Also try running CleanBody API, check if the unsupported contours are wiped off, you will get only solid.
Hi Madhukar! I have attached the zip file of the complete program. I will be really delighted if you can send any links related to know more about CleanBody API.
Thank you very much
Thanks for your project, I'm not able to compile it as it reburies some Log file, which I don't see in the attachment.
From my understanding I have tried a written a sample code of create extrude solid from database residents arc and pline.
Attached drawing file and sample code, I don't see any discrepancy, when you create a solid from profile entity, created solid doesn't absorb profile data it only copies and creates solid. Hence changing color of Solid doesn't updates profiles like Arc and Pline here.
[CommandMethod("TestMad")] public void updateSolidContourColor() { Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Request for objects to be selected in the drawing area PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection(); // If the prompt status is OK, objects were selected if (acSSPrompt.Status == PromptStatus.OK) { SelectionSet acSSet = acSSPrompt.Value; DBObjectCollection curves = new DBObjectCollection(); // Step through the objects in the selection set foreach (SelectedObject acSSObj in acSSet) { // Check to make sure a valid SelectedObject object was returned if (acSSObj != null) { // Open the selected object for write Curve acEnt = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForRead) as Curve; if (acEnt != null) { curves.Add(acEnt); } } } DBObjectCollection regions = new DBObjectCollection(); /*Creating a region in memory*/ regions = Region.CreateFromCurves(curves); // Change the object's color to Green // acEnt.ColorIndex = 3; Solid3d extrude = new Solid3d(); extrude.RecordHistory = true; SweepOptionsBuilder sob = new SweepOptionsBuilder(); Region r = regions[0] as Region; extrude.CreateExtrudedSolid(r,r.Normal , sob.ToSweepOptions()); extrude.ColorIndex = 3; /*Now remove profile contours.*/ //extrude.CleanBody(); BlockTableRecord btr = acTrans.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(acCurDb), OpenMode.ForWrite) as BlockTableRecord; btr.AppendEntity(extrude); acTrans.AddNewlyCreatedDBObject(extrude, true); // Save the new object to the database acTrans.Commit(); } // Dispose of the transaction } }
Hi Madhukar!
Thanks a lot for your detailed clarification. I have one more question, how can we hide the profile data(arc and pline in your case) as we do in CATIA, since the profile is white in color and the solid is in different color. Why I am bothered is my profile looks like attached the image. I would make the appearance uniform, so that either the profile color is red or to be hidden.
Meanwhile can I know what is the error while executing the program, so that I can send the file once again, though I have attached the complete associated files in the same file.
Thank you!
Your code reads information from a log file [My mind though log file means a .TXT 😞 ], I dint find log in the attachment initially, I realized later that there exits an excel file.
You can change the visibility of an Entity, set it to false.
