.NET
Block rotation for XYZ
2 REPLIES 2
stefan.hofer
203 Views, 2 Replies
How can i get the rotation for every axis?
the block rotation just give me one value.
BlockReference myBlock;
double rotation = myBlock.Rotation;
// Rotation for X Y and Z
Vector3d allRotations = ...?
2 REPLIES 2
_gile
in reply to: stefan.hofer
AutoCAD stores the rotations with only a vector:  the Normal of the block reference (used to define the block reference OCS with the Arbtrary Axis Algorithm) and an angle: the Rotation of the block reference in its OCS.
The rotations about X, Y and Z axis depends on the order of these rotations. It exists some conventions using Euler angles to describe these rotations (Yaw, Potch, Roll or Precession, Nutation, Spin), you can find an example with the EulerAngles class from GeometryExtensions library.
Gilles Chanteau
GileCAD
GitHub
stefan.hofer
in reply to: _gile
thanks for the example,
It seems for my example i get the block rotation with this values
BlockReference selectedBr = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForRead) as BlockReference;
BlockRotation blockRotation = GetBlockRotation(selectedBr.BlockTransform, false);
ed.WriteMessage("\nBlockname: " + sourceBlockName + " Pitch: " + blockRotation.Pitch.ToString() + " Yaw: " + blockRotation.Yaw.ToString() + " Roll: " + blockRotation.Roll.ToString()
    + " Nutation: " + blockRotation.Nutation.ToString() + " Precession: " + blockRotation.Precession.ToString() + " Spin: " + blockRotation.Spin.ToString());
// Roll = rotated around the X axis
// Pitch = rotated around the Y axis
// Spin = rotated around the Z axis
Vector3d blockRotationXYZ = new Vector3d(blockRotation.Roll, blockRotation.Pitch, blockRotation.Spin);
functions
public struct BlockRotation
    public double Nutation;
    public double Precession;
    public double Spin;
    public double Pitch;
    public double Yaw;
    public double Roll;
public BlockRotation GetBlockRotation(Matrix3d transform, bool degrees)
    if (!transform.IsScaledOrtho())
        throw new ArgumentException("Matrice non orthogonale.");
    var cs = transform.CoordinateSystem3d;
    var xAxis = cs.Xaxis.GetNormal();
    var yAxis = cs.Yaxis.GetNormal();
    var zAxis = cs.Zaxis.GetNormal();
    Matrix3d Transform = new Matrix3d(new[]
        xAxis.X, yAxis.X, zAxis.X, 0.0,
        xAxis.Y, yAxis.Y, zAxis.Y, 0.0,
        xAxis.Z, yAxis.Z, zAxis.Z, 0.0,
        0.0, 0.0, 0.0, 1.0
    Vector3d result1;
    Vector3d result2;
    // Z-X'-Z"
    double Nutation = Math.Acos(Transform[2, 2]);
    double Precession;
    double Spin;
    if (Math.Abs(Nutation) < 1e-7)
        Nutation = 0.0;
        Precession = 0.0;
        Spin = Math.Atan2(Transform[1, 0], Transform[1, 1]);
    else
        Precession = Math.Atan2(Transform[0, 2], -Transform[1, 2]);
        Spin = Math.Atan2(Transform[2, 0], Transform[2, 1]);
    result1 = degrees ? new Vector3d(ConvertToDegrees(Nutation), ConvertToDegrees(Precession), ConvertToDegrees(Spin)) : new Vector3d(Nutation, Precession, Spin);
    // Z-Y'-X"
    double Pitch = -Math.Asin(Transform[2, 0]);
    double Yaw;
    double Roll;
    if (Math.Abs(Pitch - Math.PI * 0.5) < 1e-7)
        Pitch = Math.PI * 0.5;
        Yaw = Math.Atan2(Transform[1, 2], Transform[1, 1]);
        Roll = 0.0;
    else if (Math.Abs(Pitch + Math.PI * 0.5) < 1e-7)
        Pitch = -Math.PI * 0.5;
        Yaw = Math.Atan2(-Transform[1, 2], Transform[1, 1]);
        Roll = 0.0;
    else
        Yaw = Math.Atan2(Transform[1, 0], Transform[0, 0]);
        Roll = Math.Atan2(Transform[2, 1], Transform[2, 2]);
    result2 = degrees ? new Vector3d(ConvertToDegrees(Pitch), ConvertToDegrees(Yaw), ConvertToDegrees(Roll)) : new Vector3d(Pitch, Yaw, Roll);
    return new BlockRotation() { Nutation = result1.X, Precession = result1.Y, Spin = result1.Z, Pitch = result2.X, Yaw = result2.Y, Roll = result2.Z };
public double ConvertToRadians(double degrees)
    return degrees * (Math.PI / 180);
public double ConvertToDegrees(double radians)
    return radians * (180 / Math.PI);
Technology Administrators
