.NET
Autoload plugin isn't loading Acad 2022
0 REPLIES 0
Message 1 of 1
300 Views, 0 Replies
Hey All,
We have a few desktops that have recently upgraded from AutoCad 2020 to Acad2022 and our plugin isn't loading anymore. (Works fine in 2020)
.net 4.6.1 target for all dll's in C#
Is there a logging setting I can turn on to see where it is failing to load?
Or a good method to see why it isn't loading?
APPAUTOLOAD=14
Path exists in the Support File Search path as: C:\Program Files\Autodesk\ApplicationPlugins\Automation.bundle\Contents\2015\Net
Bundle is in the plugin directory C:\Program Files\Autodesk\ApplicationPlugins\Automation.bundle\
PackageContents.xml
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage Name="appname">
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD" SeriesMin="R20.0" SeriesMax="R24.1" />
	<Components>
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Menu/menu.cuix" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Lisp/Automation.lsp" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/AddRemoveList.dll" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/AddSheetsToProject.dll" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/AddToProject.dll" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/ArchScales.dll" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/ExcelData.dll" />
		<ComponentEntry AppName="appname" LoadOnAutoCADStartup="True" ModuleName="./Contents/2015/Net/ExportImportSheets.dll" />
		<SystemVariables>
		</SystemVariables>
	</Components>
</ApplicationPackage>
0 REPLIES 0
AutoCAD Inside the Factory
