Autodesk.AutoCAD.Runtime.Exception: 'eNoDatabase'
agomezfe
agomezfe
I am writing a C#.NET program that interacts with AutoCAD through the AutoCAD .NET API.
The program changes the objects from one layer to another, if the layer does not exist it creates a new one with some parameters that are passed through a document. To open the document we use the ReadDwgFile method. We open the document in a hidden way, so that it does not run. I have tried to change the transparency of the document that I have active, and it does it without problems, it gives me an error when I do it in a file that I do not have active. So I think the error is there. Is there a way to change the transparency of a layer whose file I have opened with the ReadDwgFile method?
 The program gives an error when I want to change the transparency of the layer of a document that I do not have open.
                using (Database destinationDatabase = new Database(false, true))
                    destinationDatabase.ReadDwgFile(file.FullName, FileShare.ReadWrite, true, "");
                    using (Transaction destinationTransaction = destinationDatabase.TransactionManager.StartTransaction())
                      BlockTable bt = (BlockTable)destinationTransaction.GetObject(destinationDatabase.BlockTableId, OpenMode.ForWrite);
                        BlockTableRecord record = destinationTransaction.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                        LayerTable layertable;
                        layertable = destinationTransaction.GetObject(destinationDatabase.LayerTableId,OpenMode.ForWrite) as LayerTable;
                        foreach (ObjectId ob in record)
                            Entity eo = (Entity)ob.GetObject(OpenMode.ForWrite);
                            if (DicLayer.Keys.Contains(eo.Layer))
                                ClassLayer layer = DicLayer[eo.Layer];
                                if (!layertable.Has(layer.LayerNewName))
                                    using (LayerTableRecord layertablerecord = new LayerTableRecord())
                                        Type enumType = typeof(LineWeight);
                                        System.Reflection.FieldInfo[] fieldInfos = enumType.GetFields();
                                        Dictionary<string, FieldInfo> lineWeigthDict = new Dictionary<string, FieldInfo>();
                                        foreach (System.Reflection.FieldInfo fieldInfo in fieldInfos)
                                            lineWeigthDict.Add(fieldInfo.Name, fieldInfo);
                                        LinetypeTable acLinTbl;
                                        acLinTbl = destinationTransaction.GetObject(destinationDatabase.LinetypeTableId,
        OpenMode.ForWrite) as LinetypeTable;
                                        // Line Weight
                                        string lineWeigtName = "";
                                        String lwn = layer.LineWeight;
                                        switch (lwn)
                                            case "Default":
                                                lineWeigtName = "ByLineWeightDefault";
                                                break;
                                            default:
                                                 lineWeigtName = "LineWeight" + layer.LineWeight;
                                                break;
                                        LineWeight lineWeight = (LineWeight)lineWeigthDict[lineWeigtName].GetValue(null);
                                        layertablerecord.Color = Color.FromColorIndex(ColorMethod.ByAci, short.Parse(layer.Color.ToString()));
                                        layertablerecord.Name = layer.LayerNewName;
                                        layertablerecord.LineWeight = lineWeight;
                                        layertablerecord.LinetypeObjectId = acLinTbl[layer.LineType];
                                        Byte alpha = (Byte)(255 * (100 - Int32.Parse(layer.Transpaerncy)) / 100);
                                        Transparency transparency = new Transparency(alpha);
                                        layertablerecord.Transparency = transparency;
                                        // Upgrade the Layer table for write
                                        destinationTransaction.GetObject(destinationDatabase.LayerTableId, OpenMode.ForWrite);
                                        // Append the new layer to the Layer table and the transaction
                                        layertable.Add(layertablerecord);
                                        destinationTransaction.AddNewlyCreatedDBObject(layertablerecord, true);
                                    eo.Layer = layer.LayerNewName;
                                else
                        destinationTransaction.Commit();
                    destinationDatabase.RetainOriginalThumbnailBitmap = true;
                    destinationDatabase.SaveAs(file.FullName, true, DwgVersion.Current, null);
WonkaPet
Can you try changing the transparency after you add the layertablerecord to the database?
Try changing the transparency on line 76.
agomezfe
Thanks, the change has worked correctly for me.
