I'm trying to start AutoCAD using COM Interop but can't get it to work. If I manually start AutoCAD and set the variable "STARTUP" to 3, everything works. If I leave it at the default value of 2, it won't. My AcadApplication is valid but all of the methods throw exceptions. Here's a code snippet:
try { pACADApp = (AcadApplication)Marshal.GetActiveObject(szProgramId); fWasAutoCADRunning = true; } catch (COMException) { try { pACADApp = new AcadApplication(); } catch (Exception) { } } if (pACADApp == null) { Application.Current.Dispatcher.Invoke(() => { string szErrorMsg = string.Format("Failed to create an instance of AutoCAD. Please ensure AutoCAD is properly installed on this computer before processing.\n\nExpected program id: {0}", szProgramId); GenericMessageBox pErrorDlg = new GenericMessageBox("Process Failed", szErrorMsg, GenericMessageBox.MessageBoxButtons.OK, GenericMessageBox.MessageBoxIcon.Error); pErrorDlg.Owner = pMainWindow; pErrorDlg.ShowDialog(); }); return; } this.pProgress.szPrimaryStatus = "Sending AutoCAD command"; // Wait for AutoCAD to finish opening while (true) { try { pACADApp.Visible = true; pACADApp.WindowState = Autodesk.AutoCAD.Interop.Common.AcWindowState.acMin; break; } catch { } }
It fails to clear the "while (true)" loop. pACADApp.Visible throws an exception. In fact, all of the methods of pACADApp throw exceptions.
Any help would be appreciated.
Joe
Are you getting COM calls rejected error? Have you implemented IMessageFilter as shown in http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
