.NET
AutoCAD Civil3D: Unable to add point groups after opening windows Form
5 REPLIES 5
joshmcdalton
581 Views, 5 Replies
Hey all! I am writing a program that opens a form when the program is run. I have no problems opening the form or hopping between methods. The problem arises when I get the active civil document (or utilize it) after the form is closed. I know the import Point section is correct because it works fine in a Class Library by itself. So somewhere the form is causing problems. I have tried a multitude of solutions including CommandFlags, activating the window, and focusing the window. (Commented Lines in snippet) Any help would be appreciated! I am probably just being blind. Thanks!
Class 1
Public Class Class1
    Public Shared acadDoc As Document
    Public Shared civilDoc As CivilDocument
    <CommandMethod("MHLBF", CommandFlags.Session)>
    Public Sub RunMHLB()
        acadDoc = Application.DocumentManager.MdiActiveDocument
        civilDoc = CivilApplication.ActiveDocument
        //acadDoc.LockDocument()
        Dim f As New Form1
        f.Show()
    End Sub
    Public Sub Insertpoint()
        //Dim app As AcadApplication = Application.AcadApplication
        //app.ActiveDocument.Activate()
       //acadDoc.Window.Focus()
        Using acCurDb As Database = acadDoc.Database
            Using trans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim pointFileName As String = "C:\Users\jdalton\Desktop\091021_PCV3_ASB_SH.csv"
                Dim pointFileFormatName As String = "PNEZD (comma delimited)"
                Dim pointFileFormat As PointFileFormat = PointFileFormatCollection.GetPointFileFormats(acCurDb)(pointFileFormatName)
                Dim pointGroupId As ObjectId = civilDoc.PointGroups.Add("AddedPoints")
                Dim result As UInteger = CogoPointCollection.ImportPoints(pointFileName, pointFileFormat, pointGroupId)
                trans.Commit()
            End Using
        End Using
    End Sub
End Class
Form Class
Public Class Form1
    Public Sub InsButton_Click(sender As Object, e As EventArgs) Handles InsButton.Click
        Close()
        Dispose()
        Dim callMethod As Class1 = New Class1
        callMethod.Insertpoint()
    End Sub
End Class
Edit: Upon further inspection, ObjectLeftOnDisk = 'pointGroupIf.ObjectLeftOnDisk' threw an exception of type 'System.AccessViolationException' I also get this error. So maybe my context is screwed up or I am doing something horribly wrong
Edit 2: Continuing my investigation, if I click the app just before it grabs the active document and starts the transaction, it works. Still trying to make the app become the active window. Any help would be appreciated!
Attached is the Error in Visual Studio and the Error in CAD
Labels (4)
5 REPLIES 5
joshmcdalton
in reply to: joshmcdalton
This code is significantly watered down as to just show the basics of the problem. The form is used to get two files from a file dialogue, do some stuff and then insert 1 of the two files. Obviously, it would be easier to just import points without the form, but the form is a necessity for the big picture of the code, if that makes sense! 🙂
norman.yuan
It looks like you have not mastered AutoCAD .NET API basics yet. Namely:
1. You do not show a UI (Win Form, in your case) by calling Form.Show()/ShowDialog() in AutoCAD. You need to use
Autodesk.AutoCAD.ApplicationServices.Application.ShowModal[Modeless]Dialog[Window]() method.
2. Your  UI/Form is shown as modeless dialog (floating UI). IN this case, if the UI triggers an action to modify a drawing database, the document must be locked with Document.Lock() method, or you let the UI action calls Document.SendStringToExecute() method to call a Command method (this is recommended approach when modeless UI is used.
3. Finally, you need think hard as to using modal UI or modeless UI. The latter poses quite some challenge in AutoCAD programming if the data presented on the modeless UI is drawing specific because user could switch to another drawing while the UI is showing.
Norman Yuan
Drive CAD With Code
joshmcdalton
in reply to: norman.yuan
You are definitely right about me not mastering the basics yet. Is there a good resource for learning this?
norman.yuan
You can either go to Autodesk's online developer guide, such as this:
https://help.autodesk.com/view/OARX/2022/ENU/
or download AutoCAD ObjectARX SDK, which comes with .NET code samples (well, it only touches very limited topics).
In terms of doing UI in AutoCAD plugin, @_gile has a very good tutorial for one to get started:
https://gilecad.azurewebsites.net/UserInterfaces.aspx
Other than those, this forum is obviously a good place to learn/discuss .NET API topics.
Norman Yuan
Drive CAD With Code
Jeff_M
@joshmcdalton First off please direct Civil3D customization questions to the C3D Customization forum. Second, I sure wish you were using c# instead of VB as there are far more sample code snips available. Now, as to your specific issue in addition to what Norman mentioned, in one instance of Class1 you are setting the acad document and civil document and calling the Form. Then in the form button you close/dispose the form and create a new instance of Class1 so when you call the Insertpoint() it has no reference to the previously set documents.
Have you considered doing something like this?
        Dim f As New Form1
        If Application.ShowModalDialog(f).Status == DialogResult.OK
           Then InsertPoint()
    End Sub
not sure if that is the correct format for VB as I don't usually use it, but should be close.
Or, if you are wanting the InsertPoint to be done in a different drawing than the one which called the command, I would suggest using a side database instead. If this is the case, please post over in the C3D Customization forum and I can show you an example of this, albeit in c#.
Jeff_M, also a frequent Swamper
AutoCAD Inside the Factory
