AutoCAD BlockReference with Attribute Reference - Rotate Attribute Reference to TOP View
rberghLJ4SA
rberghLJ4SA
I am looking for some help, we have a block reference that has been placed on a UCS. I'd like to rotate the Attribute Reference to the top view for printing purposes.
The Block Reference looks like this
block reference Normal: {(-0.447489037915538,0.774278908692316,-0.447488248448676)}
block reference Rotation: 3.1415916339744827
block reference BlockTransform: {((2.07792693857256,0.537401292332017,-1.07397369099729,139.455483961257),(1.20092449302597,-0.929846906863022,1.85826938086156,127.146580516264),(2.18839580212737E-06,-2.14629554833372,-1.07397179627682,-50),(0,0,0 ,one))}
block reference Position: {(139.455483961257,127.146580516264,-50)}
The Attribute Reference looks like this
Attribute Reference Normal: {(-0.447489037915538,0.774278908692316,-0.447488248448676)}
Attribute Reference Rotation: 3.1415916339744827
Attribute Reference Position: {(140.xxx-xxxxxxxx,127.319427379831,-51.2288381400736)}
How do I go about transforming the Attribute reference so viewable from the top
rberghLJ4SA
if (br.AttributeCollection != null && br.AttributeCollection.Count != 0)
                foreach (ObjectId id in br.AttributeCollection)
                    DBObject obj = acTrans.GetObject(id, OpenMode.ForRead);
                    AttributeReference ar = obj as AttributeReference;
                    if (ar != null && ar.Normal == new Vector3d(0, 0, 1))
                        ar.UpgradeOpen();
                        Matrix3d brMat = br.BlockTransform;
                        //Keep current position
                        Point3d pos = new Point3d(ar.Position.X, ar.Position.Y, ar.Position.Z);
                        Vector3d targetNormal = new Vector3d(0, 0, 1);
                        //Set new normal and put back the position.
                        ar.Normal = targetNormal;
                        ar.Position = pos;
                        //Get projection matrix
                        Plane targetPlane = new Plane(new Point3d(0, 0, 0), targetNormal);
                        Matrix3d mat = Matrix3d.Projection(targetPlane, targetNormal);
                        //Compute the rotation on WCS.
                        //We do this by taking the XAxis of blockTransform and projecting that onto WCS.
                        //Then get the angle on plane of that new projected vector.
                        Vector3d vec = brMat.CoordinateSystem3d.Xaxis;
                        Vector3d vecTrans = vec.TransformBy(mat);
                        Plane worldPlane = new Plane(Point3d.Origin, Vector3d.ZAxis);
                        double angleOnPlane = vecTrans.AngleOnPlane(worldPlane);
                        //double angleOnPlaneDeg = angleOnPlane * 57.2958;
                        ar.Rotation = originalRotsAR[count] + angleOnPlane;
                        count++;
I 've tried this but then the text moves away from the block but it is on the correct plane facing up
rberghLJ4SA
afterafterbeforebefore
