.NET
add atribute tag and value to autocad block
7 REPLIES 7
Message 1 of 8
imagination_s
968 Views, 7 Replies
Hello Everyone,
Please help me with this
I need to add a attribute Tag and a value (position Z) to  each block on my dwg
But doing this in vb.net
Here is my code so far
 <CommandMethod("LISTATT")> _
    Public Sub ListAttributes()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db2 As Database = Application.DocumentManager.MdiActiveDocument.Database
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        ' Start the transaction
        Try
            ' Build a filter list so that only
            ' block references are selected
            Dim values() As TypedValue = { _
         New TypedValue(DxfCode.BlockName, "DOT")
            Dim sfilter As New SelectionFilter(values)
            Dim opts As New PromptSelectionOptions()
            opts.MessageForAdding = "Select blocks: "
            Dim res As PromptSelectionResult = ed.GetSelection(opts, sfilter)
            ' Do nothing if selection is unsuccessful
            If res.Status <> PromptStatus.OK Then
                Return
            Dim selSet As SelectionSet = res.Value
            Dim idArray As ObjectId() = selSet.GetObjectIds()
            For Each blkId As ObjectId In idArray
                Dim blkRef As BlockReference = DirectCast(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                ed.WriteMessage(vbLf & "Block: " + btr.Name)
                btr.Dispose()
                Dim attCol As AttributeCollection = blkRef.AttributeCollection
                For Each attId As ObjectId In attCol
                ' Dim attRef As AttributeReference = DirectCast(tr.GetObject(attId, OpenMode.ForWrite), AttributeReference)
                ' attRef.Tag = "COTA" ---------it repace other attribute
                ' attRef.TextString = attRef.Position.Z
                ' Dim str As String = ((vbLf & "  Attribute Tag: " + attRef.Tag &
vbLf & "    Attribute String: ") + attRef.TextString)
                ' ed.WriteMessage(str)
        Next
            Next
            tr.Commit()
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            ed.WriteMessage(("Exception: " + ex.Message))
        Finally
            tr.Dispose()
        End Try
    End Sub
The problem is that it  replace other atribute with COTa and the value of Position Z
7 REPLIES 7
Message 2 of 8
norman.yuan
in reply to: imagination_s
From you code, if it dificult to tell what you are trying to do. Your description is alos a bit vague. It seems that you want to add a new attribute (AttributeReference) in all existing BlockReferences, based in the same block definition, named as "DOT".
There could be 2 situation:
1. When the block references were inserted, the block definition didi not have an atribute tagged as "COTA". But now, you modified the block definition and added a new attribute definition "COTA", and you want all the corresponding block references have this new AttributeReference added by code; (you can run "AttSync" command for this, I believe).
2. Regardless the block definition having attribute "COTA" or not, you can add as many new attributereference to a block reference as you want by code.
If so, what you need is (after obtaining the BlockReference object) to simply create a new AttributeReference, and append it to the Blcokreference.AttributeCollection.
However, if you do not have a corresponding AttributeDefinition available in the BlockDefinition as template, you need to decide the AttributeReference's text properties (style, height...) and its geometric location.
Maybe, you want to clarify which situation you are in.
Norman Yuan
Drive CAD With Code
Message 3 of 8
imagination_s
in reply to: norman.yuan
YEs is correct
Number 2
I dont have attribute COTA  and a value based on the z coodonate of same attribute i want to ad it to same block
Pleas tell me how to do that
"what you need is (after obtaining the BlockReference object) to simply create a new AttributeReference, and append it to the Blcokreference.AttributeCollection."  and this
How to create a new attribute referene
is this ? -
dim new_att as atrributecollection
dim new_ref as blockeference
Message 4 of 8
norman.yuan
OK, assume there is a block definition, called "TestBlock" with no attribute included; and there are a few block references of this block have already been inserted into the drawing, say, ModelSpace; now you want to make all the block referneces show an attribute tagged as "TAG1" with a given value. Here is the code to do that:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(AddAttrToBref.MyCadCommands))]
namespace AddAttrToBref
    public class MyCadCommands
        [CommandMethod("AddAtt")]
        public static void AddAttributeToBlock()
            Document dwg = CadApp.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                ObjectId[] blkIds = SelectBlocks(ed, "TestBlock");
                AddNewAttributeToBlocks(dwg, blkIds, "TAG1");
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}\n{1}", ex.Message, ex.StackTrace);
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static ObjectId[] SelectBlocks(Editor ed, string blkName)
            TypedValue[] vals = new TypedValue[]
                new TypedValue((int)DxfCode.BlockName,blkName)
            PromptSelectionResult res = ed.SelectAll(new SelectionFilter(vals));
            if (res.Status == PromptStatus.OK)
                return res.Value.GetObjectIds();
            else
                return null;
        private static void AddNewAttributeToBlocks(
            Document dwg, ObjectId[] blkIds, string newTag)
            using (var tran=dwg.TransactionManager.StartTransaction())
                int i = 0;
                foreach (var blkId in blkIds)
                    i++;
                    AddAttToBlockReference(dwg.Database, blkId, newTag, "No. " + i, tran);
                tran.Commit();
        private static void AddAttToBlockReference(
            Database db, ObjectId blkId, string tagName, string tagValue, Transaction tran)
            BlockReference bref = (BlockReference)tran.GetObject(blkId, OpenMode.ForWrite);
            AttributeReference aref = new AttributeReference();
            aref.SetDatabaseDefaults();
            aref.Layer = "0";
            aref.TextStyleId = db.Textstyle;
            aref.Height = 0.5;
            aref.SetAttributeFromBlock(bref.BlockTransform);
            aref.Tag = tagName;
            aref.TextString = tagValue;
            bref.AttributeCollection.AppendAttribute(aref);
            tran.AddNewlyCreatedDBObject(aref, true);
See attached drawing for the effect of before and after the command runs:
Before (the block references have no attribute, based on the block definition)
 After:
HTH.
Norman Yuan
Drive CAD With Code
Message 5 of 8
SENL1362
Hello Norman,
Good sample and well written.
Just out of curiosity, is there any particular reason why you add both Database and Transaction in AddAttToBlockReference(..).
The Transaction could being extracted from the Database argument, so what's you're story behind this?
Message 6 of 8
norman.yuan
in reply to: SENL1362
It was just some code coming quick into my head, did not put too much thought.
At first I only had Transaction as argument. And when creating the new Attributereference, I realized that I needed to know the current TextStyle, which I can get from the Database object, thus, I quickly added Database as another argument for that method. That was it: not too much thought, just meant to show a working sample.
Norman Yuan
Drive CAD With Code
Message 7 of 8
SENL1362
ok. Thanks for the explanation.
Message 8 of 8
imagination_s
Norman ,your the best! 🙂
Good code
Thankyou so much for your efforts
AutoCAD Inside the Factory
