XData problem
XData problem
XData problem
I want to know whether a particular application name is registered in the Autocad or not ? I am adding XData application by following, But before this I want to check if application name is already registered or not ?
Dim tbl As RegAppTable = CType(myT.GetObject(db.RegAppTableId, OpenMode.ForWrite, False), RegAppTable)
tbl.add("ASD")
tm.AddNewlyCreatedDBObject(App, True)
I am using VB.Net and ObjectARX2006 on AutoCAD map 3D 2006.
Please help me.
Alankar
not sure about VB but in C#
tbl.Has("ASD")
Laurence
wrote in message news:5027523@discussion.autodesk.com...
tbl.add("ASD")
Please help me.
Alankar
Thanks a lot Laurence,
This function also available in VB and when I used it my problem is solved.
Thanks again.
Alankar
