Xdata maximum length
Ahmadi_rad
Ahmadi_rad
Hello
Trying to customize autocad based on Xdata, found that autocad has a maximum allowable length of 256 bytes. How to overcome this problem?
Alfred.NESWADBA
using <DbObject>.ExtensionDictionary instead of XData would be a chance.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Ahmadi_rad
Thanks a lot
Will try it and come back soon
Alexander.Rivilis
@Ahmadi_rad wrote:
Hello
256 - is a maximum length of one string, but you can use few strings such as:
(1000 . "First line")
(1000 . "Second line")
(1000 . "Third line)
But maximum total length of XData of all applications in one object/entity is 16K bytes.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
dgorsman
If you're running into that kind of limitation, it's a good idea to review what you are doing.  Perhaps it would be better to do other things, like push pointers which can be extracted and used as a lookup key in an external system.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Ahmadi_rad
Hello and thanks for the response. I'm serializing some small c# classes and adding them to drawing entities. breaking the serialization string to 256byte strings may not be the easiest, but good to know.
By the way thanks
Ahmadi_rad
I'm not a professional programmer, It takes me time to find some time in between my jobs and modify my macros. Last night I finished this solution and it worked. Thanks.
