Writing and Reading Values to An Entity's Extended Dictionary
BKSpurgeon
BKSpurgeon
I want to know if I’m doing this right:
  • In order to retrieve some data placed in a Result Buffer, I have to remember the order of the data placed in the result buffer?
  • Secondly, how does one store a vector3d in a result buffer which is to be placed in an entity’s extended dictionary?
Given Information:
Let’s suppose I have the following information:
  • Contact’s name (string)
  • Contact’s phone: (int)
  • Vector
What I want to do:
I want to add the above information to an entity’s Extension dictionary.
Am I doing this right?
Here’s the calling code:
        [CommandMethod("AddAndReadXRecord")]
        public void AddXAndReadRecord()
            RecordAdderAndReader addAndRead = new RecordAdderAndReader(Application.DocumentManager.CurrentDocument);
            addAndRead.ReadEntityXRecord();
And here are the supporting code/classes:
    public class RecordAdderAndReader
        private Document doc;
        private Database db;
        private Editor ed;
        private ObjectId entityId;
        // the name of the Xrecord which will be added
        private const string markNo = "MarkNo";
        public RecordAdderAndReader(Document doc)
            this.doc = doc;
            this.db = doc.Database;
            this.ed = doc.Editor;
            PromptEntityResult entityResult = ed.GetEntity("Select entity to add the " + markNo + " Xrecord to it's extension dictionary. The Default No will be it's Handle.");
            if (entityResult.Status != PromptStatus.OK)
                return;
            else
                // set the panel name - to it's handle.
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    DBObject entity = tr.GetObject(entityResult.ObjectId, OpenMode.ForRead) as DBObject;
                    this.entityId = entity.Id;
                    string defaultPanelName = entity.Handle.ToString();
                    XRecordAdderHelper xRecordAdder = new XRecordAdderHelper(entity.Id);
                    xRecordAdder.PersistDataToObject("MarkNo", entity.Handle.ToString());
                    tr.Commit();
        public void ReadEntityXRecord()
            XRecordReader reader = new XRecordReader(markNo);
            reader.readValue(entityId);
    internal class XRecordAdderHelper
        private readonly ObjectId id;
        private ObjectId extensionDictionaryId;
        public XRecordAdderHelper(ObjectId id)
            this.id = id;
            addExtensionDictionaryIfItDoesNotExist(id);
        private void addExtensionDictionaryIfItDoesNotExist(ObjectId id)
            Database db = id.Database;
                DBObject dbObj = tr.GetObject(id, OpenMode.ForRead);
                this.extensionDictionaryId = dbObj.ExtensionDictionary;
                if (extensionDictionaryId == ObjectId.Null)
                    dbObj.UpgradeOpen();
                    dbObj.CreateExtensionDictionary();
                tr.Commit();
        public void PersistDataToObject(string xRecordName, string dataValue)
                // get the extension dictionary
                DBDictionary extensionDictionary = tr.GetObject(this.extensionDictionaryId, OpenMode.ForWrite) as DBDictionary;
                // set up the data.
                List<TypedValue> typedValues = new List<TypedValue>
                    new TypedValue((int)DxfCode.ExtendedDataAsciiString, "Freddie Mercury")
                    , new TypedValue((int)DxfCode.Int32, 123456)
                    , new TypedValue((int)DxfCode.Real, 1)
                    , new TypedValue((int)DxfCode.Real, 0)
                }; // If I want to add a Vector, am I doing this right?
                ResultBuffer rb = new ResultBuffer(typedValues.ToArray());
                // add the data to the XRecord
                Xrecord xrecord = new Xrecord();
                xrecord.Data = rb;
                // add the Xrecord to the ExtensionDictionary
                // what if the record already exists? Add error checking for this.
                extensionDictionary.SetAt(xRecordName, xrecord);
                tr.AddNewlyCreatedDBObject(xrecord, true);
                tr.Commit();
    public class XRecordReader
        private readonly string xRecordEntryNane;
        private Editor ed;
        public XRecordReader(string xRecordEntryNane)
            this.xRecordEntryNane = xRecordEntryNane;
            this.ed = Application.DocumentManager.CurrentDocument.Editor;
        public void readValue(ObjectId objectId)
            string name = "";
            int phoneNumber = 0;
            double vectorX = 0;
            double vectorY = 0;
            double vectorZ = 0;
            using (Transaction tr = objectId.Database.TransactionManager.StartTransaction())
                DBObject dBObject = tr.GetObject(objectId, OpenMode.ForRead) as DBObject;
                DBDictionary extensionDictionary = tr.GetObject(dBObject.ExtensionDictionary, OpenMode.ForRead) as DBDictionary;
                if (extensionDictionary.Contains(xRecordEntryNane))
                    Xrecord xrecord = tr.GetObject(extensionDictionary.GetAt(xRecordEntryNane), OpenMode.ForRead, false) as Xrecord;
                    if (xrecord != null)
                        ResultBuffer rb = xrecord.Data;
                        if (rb != null)
                            TypedValue[] tvArray = rb.AsArray();
                            for (int i = 0; i < tvArray.Length; i++)
                                if (i == 0)
                                    name = (string)tvArray[i].Value;
                                else if (i == 1)
                                    phoneNumber = (int)tvArray[i].Value;
                                else if (i == 2)
                                    vectorX = (double)tvArray[i].Value;
                                else if (i == 3)
                                    vectorY = (double)tvArray[i].Value;
                                else if (i == 4)
                                    vectorZ = (double)tvArray[i].Value;
                            rb.Dispose();
                // print all the results
                ed.WriteMessage("\nName: " + name);
                ed.WriteMessage("\nPhone: " + phoneNumber.ToString());
                ed.WriteMessage("\nVector Values: X:" + vectorX.ToString() + ", V: " + vectorY.ToString() + " Z: " + vectorZ.ToString());
                tr.Commit();
Your ideas/assistance is much appreciated.
_gile
hi,
I'd rather use some more generic extension methods to set or get Xrecords in (extension) dictionaries.
    static class Extension
        public static void Check(this ErrorStatus es, bool condition, string msg = null)
            if (!condition)
                if (msg == null)
                    throw new Exception(es);
                else
                    throw new Exception(es, msg);
        public static T GetObject<T>(
            this ObjectId id,
            OpenMode mode = OpenMode.ForRead,
            bool openErased = false,
            bool forceOpenOnLockedLayer = false)
            where T : DBObject
            ErrorStatus.NullObjectId.Check(!id.IsNull);
            Transaction tr = id.Database.TransactionManager.TopTransaction;
            ErrorStatus.NoActiveTransactions.Check(tr != null);
            return (T)tr.GetObject(id, mode, openErased, forceOpenOnLockedLayer);
        public static DBDictionary TryGetExtensionDictionary(this DBObject source)
            Assert.IsNotNull(source, nameof(source));
            ObjectId dictId = source.ExtensionDictionary;
            if (dictId == ObjectId.Null)
                return null;
            return dictId.GetObject<DBDictionary>();
        public static DBDictionary GetOrCreateExtensionDictionary(this DBObject source)
            if (source.ExtensionDictionary == ObjectId.Null)
                source.UpgradeOpen();
                source.CreateExtensionDictionary();
            return source.ExtensionDictionary.GetObject<DBDictionary>();
        public static ResultBuffer GetXDictionaryXrecordData(this DBObject source, string key)
            Assert.IsNotNullOrWhiteSpace(key, nameof(key));
            DBDictionary xdict = source.TryGetExtensionDictionary();
            if (xdict == null)
                return null;
            return xdict.GetXrecordData(key);
        public static void SetXDictionaryXrecordData(this DBObject target, string key, params TypedValue[] values)
            target.SetXDictionaryXrecordData(key, new ResultBuffer(values));
        public static void SetXDictionaryXrecordData(this DBObject target, string key, ResultBuffer data)
            Assert.IsNotNull(target, nameof(target));
            target.GetOrCreateExtensionDictionary().SetXrecordData(key, data);
        public static ResultBuffer GetXrecordData(this DBDictionary dict, string key)
            Assert.IsNotNull(dict, nameof(dict));
            if (!dict.Contains(key))
                return null;
            ObjectId id = (ObjectId)dict[key];
            return id.GetObject<Xrecord>().Data;
        public static void SetXrecordData(this DBDictionary dict, string key, params TypedValue[] values)
            dict.SetXrecordData(key, new ResultBuffer(values));
        public static void SetXrecordData(this DBDictionary dict, string key, ResultBuffer data)
            Xrecord xrec;
            if (dict.Contains(key))
                xrec = ((ObjectId)dict[key]).GetObject<Xrecord>(OpenMode.ForWrite);
            else
                dict.UpgradeOpen();
                xrec = new Xrecord();
                dict.SetAt(key, xrec);
                dict.Database.TransactionManager.TopTransaction.AddNewlyCreatedDBObject(xrec, true);
            xrec.Data = data;
    static class Assert
        public static void IsNotNull<T>(T obj, string paramName) where T : class
            if (obj == null)
                throw new System.ArgumentNullException(paramName);
        public static void IsNotNullOrWhiteSpace(string str, string paramName)
            if (string.IsNullOrWhiteSpace(str))
                throw new System.ArgumentException("eNullOrWhiteSpace", paramName);
Then you can simply use these extension methods in specific contexts.
To add a vector to a resultbuffer, a trick is to convert it into a point (this can be done by adding the vector to the Point3d.Origin). To get the vector from the point, you can use the getAsvector method.
        [CommandMethod("AddMarkNo")]
        public static void AddMarkNo()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var per = ed.GetEntity("\nSelect entity: ");
            if (per.Status != PromptStatus.OK)
                return;
            var name = "Freddie Mercury";
            var phone = 123456;
            var vector = new Vector3d(1.0, 0.0, 0.0);
            using (var tr = db.TransactionManager.StartTransaction())
                var ent = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                ent.SetXDictionaryXrecordData(
                    "MarkNo",
                    new TypedValue(1, name),
                    new TypedValue(90, phone),
                    new TypedValue(10, Point3d.Origin + vector));
                tr.Commit();
        [CommandMethod("ReadMarkNo")]
        public static void ReadMarkNo()
                return;
                var ent = tr.GetObject(per.ObjectId, OpenMode.ForRead);
                var resbuf = ent.GetXDictionaryXrecordData("MarkNo");
                if (resbuf != null)
                    var data = resbuf.AsArray();
                    string name = (string)data[0].Value;
                    int phone = (int)data[1].Value;
                    Vector3d vector = ((Point3d)data[2].Value).GetAsVector();
                    ed.WriteMessage($"\nName: {name}");
                    ed.WriteMessage($"\nPhone: {phone}");
                    ed.WriteMessage($"\nVector: {vector}");
                else
                    ed.WriteMessage($"\nMarkNo not found");
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
dgorsman
If order is a consideration, you might consider putting different data in different XRecords so you can call them by name.  It makes it easier to do things like use const strings for names.
I generally try to avoid dependency on the order of data as it makes further development a bit easier e.g. removing obsolete data doesn't require a mass reshuffling of index values.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
BKSpurgeon
hi Gilles
having some issues here:
            this ObjectId id,
            where T : DBObject
            ErrorStatus.NullObjectId.Check(!id.IsNull); // ErrorStatus does not contain a definition for Null ObjectId - is this
Please ignore  - This has been fixed:
The problem was a using statement: to using Autodesk.AutoCAD.Runtime;
