Window does not contain a definition for window
I have been learning how to resize the model space and app and I tried to use this code from "through the interface" but it brings up the following error in the image. I added Presentationcore.dll because that is all that I have been able to find  on  pplication.DocumentManager.MdiActiveDocument.WindowApplication.DocumentManager.MdiActiveDocument.Window
running win10 home
tried updating .net from 4.6 to 4.7
autocad2017
norman.yuan
You did not say, but obviously you are using newer AutoCAD version than AutoCAD2009/2010, which was the version Kean's article based on.
The 2 properties "Location" and "Size" of the class Autodesk.AutoCAD.Windows.Window in AutoCAD2009/2010 has changed in later versions of AutoCAD (I could not recall which, 2012, or 2013?) to "DeviceIndependentLocation: and "DeviceIndependentSize".
Norman Yuan
Drive CAD With Code
Thank you.
